How much shock travel?
#41
No, all the weight will be on the one hub and the spring will compress more than usual. Measure the exact height from the ground to the center of the hub. Remove the wheel and jack the hub back to that same level.
#42
Originally Posted by boyguan' timestamp='1364276277' post='22428674
That's as close as mine
Can I take the wheel off and jack it up on the arm till it comes off the jack stand to resemble it being on the ground?
Guessing where the center of the hub is has more variance.
#43
So I measured the points
The front looks like 11.5 to top of hub cover and 12.25 at center of hub. Looks like 2.5 inches of travel which is great
[attachment=36462:image.jpg]
[attachment=36463:image.jpg]
The rear measures 11 at top of hub and 12 at center of axle. Travel looks to be 1.2-1.5 inch of travel
[attachment=36464:image.jpg]
[attachment=36465:image.jpg]
I am raising the car 0.5 at the spring so that should give me some additional travel. I hope the rear feel changes as I think I was kissing the bump stops under hard loads
#45
decepticondc5
12-25-2016 01:49 AM
Wildass
05-24-2004 01:52 PM
