How often are you changing your oil (after/between events)?
#21
What I also think is worth noting is minimizing any pressure drop from adding an oil cooler. I noticed a ~7psi pressure drop in vtec when the thermostat was fully open on the oil cooler. To compensate for this I drilled a small hole in the sandwich plate which allows oil to bypass the oil cooler and pressure is back to "normal." Of course with very hot oil (pre-oil cooler) I saw pressures fall as well on track at 280F+, but oil pressure is obviously critical.
#23
#25
I'm going to be monitoring these things much closer now that I've officially shaken down the new motor. Planning to change oil after every event.
140k mile F20C. Using Motul 10w-40 6100 Synergie+. Stock oil pan.
Mishimoto radiator, no oil cooler, Honda oil filter. Cusco catch can.
The car is driven 4 hours total to and from the track pulling a 600-700lb tire trailer. That keeps the motor under a little more load. On-road oil consumption is normal.
After 2 30-minute sessions at Sebring, I found the car to have burned almost 1/3 quart of oil. Ambient temps were around 88-90 degrees last weekend and oil consumption was consistent throughout the 2 day event. Just emptied the catch can, topped up the oil level and went back out. Wound up consuming just under 2 quarts over both days.. I will be sending an oil analysis out since it was the first full event with the new motor and oil. If it looks an oil cooler will help, I will install one.
I need to find a new catch can setup with a little more volume. Vent to atmosphere with no filter was... messy
#26
#27
#28
I change mine every 5-6 days. I have 175k on my car, it still leaks down <5% and made a dynojet 206whp last month. It does go through about half a quart a day, depending on the track.
