How to separate softtop frame and mounting bracket
Old Jan 29, 2011 | 10:15 AM
turbo8765's Avatar
Default How to separate softtop frame and mounting bracket
I have the complete soft top frame out of the car.
How do I separate the frame from the mounting bracket that I will need to re-use for the mounts for the hard top?
Old Jan 29, 2011 | 12:28 PM
tekka01's Avatar
you will have to cut the side plates out. i think most ppl just leave it out of the car, the hardtop will still install without it. the cr has side gusset plates that are basically the same thing
Old Jan 29, 2011 | 01:49 PM
ddess's Avatar
I agree on cutting it.
I just removed mine and I wondered the same thing but instead of breaking out a hacksaw I bought the Izzy's rear race brackets and problem solved.
Old Jan 29, 2011 | 04:08 PM
turbo8765's Avatar
Do you have a link for the brackets? Looks to me like the stock brackets are better in that they have more attachment points. May be breaking out the hacksaw/grinder.
EDIT: Googled and found the link.
Old Jan 29, 2011 | 04:10 PM
ddess's Avatar
http://www.izzyscustomcages.com
Old Jan 31, 2011 | 07:50 AM
turbo8765's Avatar
Used a plasma cutter. Took about 4 minutes.
Old Jan 31, 2011 | 09:45 AM
TubeDriver's Avatar
If you cut them off, the softop becomes useless. Just get izzy mounts or you could order the plates from Honda (since they come with the CR).
Spoolin
Apr 2, 2017 08:28 AM
mr.domo
Apr 16, 2014 02:27 AM
Topplayer
Dec 7, 2012 06:05 PM
Topplayer
May 17, 2012 08:27 PM
Silver5656
Apr 19, 2012 08:07 PM
