How would these fit?
Old Apr 21, 2011 | 03:54 PM
usafstud's Avatar
Default How would these fit?
Looking for deal on track wheels and found a set of near new rfp1's. The thing is they are (4) +45 offset. How would thesr work? Looking into using 255 rs-3's.
Thank
Old Apr 21, 2011 | 04:29 PM
Chhewy's Avatar
roll front and roll back fenders, and relocate bumper tab and you are good to go.
Old Apr 21, 2011 | 07:00 PM
usafstud's Avatar
besides rubbing, do offset have any impact to handling performance?
Old Apr 21, 2011 | 07:01 PM
ddess's Avatar
^ Thats what I did. I also run -3 camber front and rear. no issues with any rubbing.
Old Apr 22, 2011 | 03:03 AM
robrob's Avatar
I run those exact wheels with Hoosier R6 245x17s and they will rub unless you roll the fenders and move the rear bumper attachment tab to the rear about 1/2 inch. The 245 Hoosiers are about the same width as a normal 255, but I'm not familiar with the RS-3s. These wheels also clear 2 1/2 inch brake duct hose with no rubbing. The +45 will widen your track a little which is good.
Old Apr 23, 2011 | 05:10 AM
usafstud's Avatar
Thanks y'all
Old Apr 23, 2011 | 07:39 AM
'09S2K's Avatar
17x9's right? I'm running the same exact setup. It is much more aggressive than I was expecting it to be but it works. Fenders rolled, tab relocated, trim rear bumper or let the tire rub the tab til it's gone haha. Which is what I did -3.3 camber front/rear.
Old Apr 23, 2011 | 07:44 AM
usafstud's Avatar
WHat is the max camber setting u can get on stock suspension front and rear? What about with camber joints?
Old Apr 23, 2011 | 01:09 PM
robrob's Avatar
For me it was -1.9 front (and that's with a reduction in caster, which is not good) and I never tried to max the rear until I had replaced my rear control arm which allows more camber. My max with just the control arms is -3.0 in the rear. With adjustable ball joints or J's offset ball joints you can go to over -4 front and rear, which is just crazy.
Silvers2kdaily
Jul 19, 2015 05:47 AM
RagingCheese
Feb 19, 2014 07:22 AM
whitt1
Nov 14, 2011 02:50 PM
Rxmfn7
Jun 10, 2008 07:06 PM
lautll421
Apr 7, 2008 06:23 AM
