Imput on S2K vs FD3S comparison..
So as a previous S2K owner, then EVO IX owner, now considering another FD3S to K24 swap and want some of the S2K guys that track their cars to give some real world weight:whp comparison to see if the car is a worthwhile budget type track/daily build. Thanks in advance!
No input on your question... but I'd suggest a J32 swap over a K24. Weight is close enough to not matter, but it's a shorter engine, so it'll give you better weight distribution, and it's a V6... so you know, torque... just my 2 cents
So my issues with the J32 is there isn’t enough aftermarket support and I’m not sure if they make a trans adapter plate for them. Remember TQ isn’t the biggest concern when the Kseries aftermarket is readily available and cheap, plus clears the hood.
2) Wt/hp doesn't define a track day car or a DD. Real race cars are often HP limited. The two most popular SCCA classes are Spec Miata (2200#, 135hp) and Spec Racer Ford (1600#, also 135hp). DTM is limited 500hp. Indy basically has a spec engine. Today's technology makes mega hp relatively easy to achieve. It isn't easy to use. In drag racing, they would require safety equipment that compromises street functionality. As a DD, how much hp can you use? Is a car more fun when 3 seconds of wide open throttle passes the speed limit and the noise alerts all police within 1/2 mile, or when you can flog it without receiving attention. In the muscle car heyday of the 1960s, 14sec@100hp was the benchmark of a really fast car and most 'sports cars' where 16+sec@80 something or slower. Sometimes much slower. Then can the 1970s emissions rules and the OPEC gas crisis inspired fuel economy rules and the cars got slower. Corvettes where mid-16s@80 something.
3) Road course driving is supposed to be amount handling. Carrying speed through corners. Powering out early and hard. Handling and aero far more important than a few mph down a long straight. At a track day/HPDE event, you aren't braking hard and late to go fender-to-fender to fight for position. Even in NASA, the classes are in a wt/hp basis. More power just puts you in a faster class with fewer competitors.
4) The FD3S started life with a 250lb engine; all the Hondas from a B-series, to a K-series 400lb. A J-series is around 550lb. Why not just tie someone to your hood?
If you want to build an interesting swap, build one...but it is unlikely to be either a reliable DD or a reliable well-balanced track day car. It can be unique and you can have some fun dyno racing it.
If you want to get track day seat time, get something that can run and run and run and run with minimal maintenance and where the reliability issues are worked out. There is another active thread on that. I made recommendations for a dedicated track day car (SRF) and track day/DD (Mustang PP2, recommend 2019 model to delivered early July).
If you want to do a swap, I recommend putting a 2JZ-GTE VVTi or LT4 into just about anything. The LT4 is $15k + electronics, 650hp tractable hp from the factory and very compact. The JDM 2JZ-GTE VVTi is imported from Japan by several sources and under $3k. Change the turbo and maybe the intake, say $15k-$20k, and you can have 1000+hp. S2k conversions are common, as are FT86/BRZ. And many others. It will be limited to the LT4 levels on pump gas, but on E85 or with water/methanol injection 1500+hp is fairly straightforward to get. That would be totally useless at track day.
You actually believe that a 13B fully dressed is heavier than an all aluminum K24? Let me guess you think an LS aluminum v8 is a boat anchor too? This isn’t my first rodeo on swapping and reliability of the k24 with the good handling FD chassis is ideal to me because of same weight of an S2K but more cabin room and more wheel/tire. I appreciate your well written reply but I think some of your info is lacking. I too agree with you a less powered well geared car with efficient grip is what I’m looking for.
I did get the weights wrong. 250 was right for a 13B, but this is a 13BREW. So...yes about the same weight.
Still...why? Does the F3DS have any advantage over an S2000?
Its been done before, but unclear if the Australian conversion is the only one.
http://youtu.be/303OresIVJw
K-Tuned built a yellow one as well. Believe it or not its actually right around 80LBS lighter fully dressed. As I said in my last post, and what I’m looking for as a comparison with the S2K the FD3S has a few advantages and one major disadvantage. The pros being more cabin/headroom/hatch, longer and wider wheelbase, and the ability run for a wider tire up front than the S2K can fit out back. Rear end options are available with the ford 8.8’s and I actually already have a bunch of parts, wheels (17x10, 17x11 CCW) that fit the FD3S. The only con that I can see is if you wreck its much harder to find a donor car, but replacement wide body parts are readily available. I’m not sure how much a S2K complete roller is going for these days but I have an opportunity to buy a decently priced FD and think that the two cars are a good comparison. I’ve ridden in a track prepped bolt on S2K and it was a blast on the road course, just lacked a little HP/TQ which I think the K24 can solve.
You are making modifications to a 16-to-26-year-old sports car where the number of conversions can be counted on one hand. It may be a fun street rod. It could do an occasional track day and may run without incident on some of them. You can drive it on the street, maybe even with A/C and not overheating...maybe.
However, it won't be as reliable and practical a track car or a street car as the options in the other thread. The extensive time and money going into the conversion is time not spent on the track. There are virtually no decent tires available in 17" diameter anymore wider than 255 other than Hoosier race tires (this is also a Supra issue). If you want tires for rims that width and in the right diameter you need to go 18", and then the A052 is really the only option with a rear that wide (315/30-18, which is 1/2"taller). In 19" and 20" sizes there are lots of tires, but those are an inch or more taller.
Net: if you like conversion projects and the old Mazda RX-7 interests you, go for it. If your goal is fun time behind the wheel rather than under the car, or you like to get to work on time regardless of the weather, there are (much) better options.
P.S.
If you would like 800hp and a DCT trans, you could do a Supra or 2JZ VVTi conversion with the Garage Whifbiz kit to adapt an E90 M3 DCT.
P.S.
2JZ motors are simply too heavy and too tall. They make great power for cars that do not like to turn. I’m not sure where you think a swapped car lacks reliability or would possibly overheat. Thanks again for the feedback, whether it’s good or bad.
