Installed Sparco lapbelt
After two posts, lots of searches and few responses to specific question, I, bit the bullet and bought a lap belt. The way I installed it is not ideal but it is easy. I used the stock belt mounts and bolts(the seat has to be removed to access both). By removing some washers and moving others around it works out somewhat. My only problem is one side of the sparco is mounted on the outside of the stock belt and one is mounted on the inside of the stock belt (hope you understood that). Although this is not the best set up both sparco and stock belts can be used similtaneously.
In use this setup is very helpful. The belt holds you firmly in the seat. You no longer have to brace yourself as much providing a finer ability to manipulate the controls.
Sep 27, 2005 04:36 PM
