Racing bucket seat w/ Stock seatbelts
I need some assistance on properly using the stock seatbelts on a racing seat until I can get proper roll over protection to use a 6pt harness with.
I've read through coral docs thread about proper use of 4,5,6 pt harnesses but he did not mention much about using the stock 3pt harness with a racing seat.
I am having trouble figuring out what the proper way is to wear the belt, whether it be over the seat or through the slots intended for the harnesses? Should I run the belt through the top left slot and the bottom left slot with the stock belt receptor on the outside of the right leg bolster? Or just have the belt over the bolsters of the seat?
I know many of you run the stock belts with racing seats to/fro events and then use 5,6pt harnesses while participating in them. Any input would be greatly appreciated.
Here's how I do it. Note that I had to replace the belt receptacle on the right side of the seat with a flexible strap, as the stock piece would not fit through the hole in the seat.
This works quite well, especially when I use a device like the CG Lock to secure the belt.
With my race seat (Recaro SPG) I wear the stock belts on the street and 6-point on the track. I run the stock belts over the sides as a slight compromise of safety and practicality. I find that it is still snug on my lap because the sides of the SPG are low and don't go above my thighs/hip, and if you run the belt through the holes you would have to detach the belt from the left-lower anchor each time you remove the seat. I believe if you leave the stock belt in the hole it might also interfere with the wide lap belt of the 6-point. This pic is not a very good one for showing the stock belts, but you can still see that I attached the right-side receptacle for the stock belt to the Taitec frame. Since I occasionally swap in the stock seat, I got an extra right-side receptacle so I have one on each seat (so just 5 min to swap seats).
Thanks for all the suggestions. I ran them both ways. I found the stock belt through the shoulder harness slots were too uncomfortable for me. So currently, I have the belt going around the should bolster and through the lap belt slot as boyquan & depletedUfoot suggested.
I don't know if they're all the same, but I went to a salvage yard and got the necessary piece out of the back seat of some Honda. I think it was the extra seat belt for a third passenger in the back seat -- most of the others are in rigid mounts.
What's the effect of driving around with the latch sensor disconnected? I know it throws a warning light on the dash, but does it start doing anything annoying like beeping if you continue for too long?
