J's racing rear control arm and tie rod end sets
Old Jun 14, 2006 | 01:28 PM
trivium's Avatar
Banned
Default J's racing rear control arm and tie rod end sets
----Js Racing Rear Control Arm Set, Pillow Ball
http://www.bulletproofautomotive.com/catal...ail.php?ID=2151
"These control arms result in increased cornering speed and stability. Alignment adjustments can be made easily."
-----Js Racing Tie Rod End Set, PIllow
http://www.bulletproofautomotive.com/catal...ail.php?ID=2148
"Improved steering response and adjustability."
Are any of these parts worth it? Or are they just extra crap to put on an s2000?
BTW, do these parts decrease the turning radius? If not, how do you decrease it?
Old Jun 14, 2006 | 01:32 PM
mikegarrison's Avatar
The rear control arm is pretty much the same thing as the TC designs anti-bumpsteer kit. Feel free to read the many discussions about bumpsteer elsewhere in this forum.
To decrease the turning radius you basically need to shorten the wheelbase (or put in rear-wheel steering), so the answer is "no".
Old Jun 14, 2006 | 02:03 PM
trivium's Avatar
Banned
I was under the impression that if you get wider fenders, wheels spacers (using stock wheels), and adjust the tie rod, you can shorten the turning radius.
IM Assuming this can also be done by playing with the caster. But I dont think messing to much with the caster will help the handling or stability.
Old Jun 14, 2006 | 02:09 PM
If you add the capability for more lock to the front wheels, you will decrease the turning radius. But these parts aren't going to do that. And if you are designing the car from scratch, adding rear wheel steering or decreasing the wheelbase is a more efficient way to do it.
Old Jun 14, 2006 | 02:10 PM
krazik's Avatar
Administrator
where did you hear that?
"playing with the tie rod"? you could toe out one side and tow in the other, that would decrease the radius in one direction
And doesn't a wider stance/width increase the turning radius?
Old Jun 14, 2006 | 02:16 PM
trivium's Avatar
Banned
I dont know. But it seemed logical that with the wider fenders, you could get the tire to turn more outwards, therefore allowing a shorter turning radius. Does it seem illogical or is it too complicated?
Old Jun 14, 2006 | 02:20 PM
That's "adding more lock".
Old Jun 14, 2006 | 03:20 PM
trivium's Avatar
Banned
and what exactly is the end result?
Old Jun 14, 2006 | 03:23 PM
OK, back to square 1:
No, these parts will not decrease turning radius.
Old Jun 14, 2006 | 04:19 PM
trivium's Avatar
Banned
I can read. But what about my previous statement, which you replied to by saying: "thats adding more lock" ?
