Knocking Comptech Bar
Biggest change was in the bolt and bolt hole area. The bolt is much beefier and there is no welded in sleeve on the inner bar in the new design. I think the new bar is stiffer also. I have some pics and will post them if I can put my hands on 'em.
As I recall, the inner bar is thicker, prolly to make up for the lack of sleeve. Otherwise, they're the same bar - the new thickness adds 30% to the stiffness.
I got mine replaced when I removed it and couldn't move the adjustment bolt. Ended up drilling it out. The new bar won't have that problem since there's no sleeve to bind to.
Originally posted by CoralDoc
My bar started creaking and clunking. A liberal grease job and new teflon tape solved that problem. I'm using the bar on the next-to-stiffest setting, and so far haven't noticed any cracking or hole elongation problems. Guess I'm not driving hard enough
The bar was replaced by Comptech without hassle. I like the slightly stiffer design of the V2 bar on concrete and even get understeer on asphalt with the bar set at its stiffest position!
