Koni yellow and GC
Hi, I am planning to order ground control And need to know what spring rates to use for my needs. My car is dd and I plan to track it few time a year, so far my setup is non stag with 255 all round and saner fsb. Also would 12k front, 10k rear be a good choice?
Thanks
Thanks
On the stock valving people say these shocks are good up to around 500lbs.
I have run 600/500lbs springs for a short period of time and they worked ok.
I'd go around 500/500 or 550/500 with that swaybar - it depends what balance you want.
And hit me up if you want to buy a ground control set with 500 and 550 lb. springs (Have Koni's too, but only 3, one is broken)
Bill
I have this set-up also. OTS Konis with 500F/450R spring rates... its a good entry level set-up for autocross. But ideally you'd want more spring...
You can put more spring on there, people do it. But it trashes the shocks quickly and leaves you vastly under-damped.
tcjensen
Aug 27, 2013 10:38 AM
