Koni yellow and GC
Old Aug 15, 2012 | 12:13 AM
s20009k's Avatar
Default Koni yellow and GC
Hi, I am planning to order ground control And need to know what spring rates to use for my needs. My car is dd and I plan to track it few time a year, so far my setup is non stag with 255 all round and saner fsb. Also would 12k front, 10k rear be a good choice?
Thanks
Old Aug 15, 2012 | 06:23 AM
dan_uk's Avatar
On the stock valving people say these shocks are good up to around 500lbs.
I have run 600/500lbs springs for a short period of time and they worked ok.
I'd go around 500/500 or 550/500 with that swaybar - it depends what balance you want.
Old Aug 15, 2012 | 08:17 PM
bsyeth's Avatar
Originally Posted by dan_uk
On the stock valving people say these shocks are good up to around 500lbs.I have run 600/500lbs springs for a short period of time and they worked ok.I'd go around 500/500 or 550/500 with that swaybar - it depends what balance you want.
I 2nd this Answer
And hit me up if you want to buy a ground control set with 500 and 550 lb. springs (Have Koni's too, but only 3, one is broken)
Old Aug 16, 2012 | 09:56 PM
s20009k's Avatar
Will it be better to have the ground control top hats with it?
Old Aug 17, 2012 | 01:16 AM
jw1's Avatar
jw1
You are going to want the GC top hats as the Koni's are stock length and you are going to need the extra bump travel when you lower it.
Old Aug 19, 2012 | 07:59 AM
Blacksol's Avatar
Thanks
When I bought my Koni's they would not sell me anything over 500. I was told anything heavier would wreck the shock? I went with 400/450 and it's fine.
Bill
Old Aug 20, 2012 | 04:32 AM
Vyndictive's Avatar
I have this set-up also. OTS Konis with 500F/450R spring rates... its a good entry level set-up for autocross. But ideally you'd want more spring...
You can put more spring on there, people do it. But it trashes the shocks quickly and leaves you vastly under-damped.
Old Aug 22, 2012 | 06:36 AM
s20009k's Avatar
when i was talking to someone at ground control they said the max spring rates for ots koni yellow is 600lb. anyone know if its true?
mrs2kny
Feb 29, 2016 05:41 PM
tcjensen
Aug 27, 2013 10:38 AM
Grip Hrd
Jul 19, 2013 11:30 AM
bkmagby
Dec 4, 2006 10:20 AM
chungtaho0918
May 15, 2002 11:58 AM
