Lap belt mounting on a PCI mount
I haven't mounted the subs and lap belts yet, planning to do that any day now. I did do my research and spoke with Schroth to make sure the plan is valid. The 01324 will be used for both laps and subs and mount to the PCI bracket and OEM belt mounting, i.e. no cutting or drilling of the body. It's not yet a proof of concept but it's the plan of record at this point. The goal is to install the belts before my next event on 4/7.
I plan to use the bracket. I know some have concerns over using the seat bracket, but PCI designed the bracket for this purpose. My only concern was the eye bolt on the tunnel side, but it seems the solution is that part linked.
Another safety concern I thought with bolting to seat bracket is if the bolts holding down the seat fail in an accident then your flying off with the seat compared to if it were hard mounted to chassis.
The first was as you mentioned above that the seat bracket mounting locations for the harnesses could fail as well.
You have shoulder harnesses that connect to a harness bar & the outside lap belt so not all of your force is into the seat. In any case if your body generates enough force to break the bolts on the seat I think you are done for regardless. They make the bracket to be bolted to and I want to say NASCAR actually bolts to their seat. IMO it isn’t anymore dangerous than drilling between your fuel lines
In my opinion, if you do something do it right, especially when it concerns safety in a dangerous sport. What difference does drilling a few holes really matter in the grande scheme of things
things.
Your post has a few ignorant/incorrect suggestions.
So you think drilling between the fuel lines doesn’t come with safety risks? Have you looked into the thickness of the metal on the OEM body and the resulting strength of using it with a backing plate vs the PCI bracket? You seem to be making a lot of assumptions and claims with no data beyond “it is how everyone else has done it”.
And you always have a single failure point, the single bolt holding the harness to whatever you bolt to. I am not sure how a seat bracket with 4 bolts becomes the “single failure point”.
I think your last comment is a bit of the pot calling the kettle black.
You're welcome to proceed however you'd like, I'm just giving you my two cents. I design things like this for a living so I tend to be on the more conservative side. Unrelated comparisons to Nascar and OEM mounting don't work for me, as the system is completely different. I would follow instructions from harness manufacturers much closer than a PCI mount.
There is a lot of qualification testing that comes with being FIA/DOT approved. I doubt PCI has done any destructive testing on their mounts. Have they run the load case of an accident on their sub mounts? By reading "we can achieve the same strength if not more" in their description I know they have no real evidence to back anything up.
I'm not saying don't use their mount, I just don't think you should also attach your harnesses to it.
Also, make sure the shear strength of the eyebolts for your lap belts are equivalent to OEM.
I have found this to be very informative and helpful:
http://www.trackhq.com/forums/attach...stallation.pdf
I apologize if I ever come off across as a jerk. I have a very blunt personality. If you ever met me I'm one of the nicest guys when you can see my enthusiasm but on forums and texting I seem like an ass.
where do people buy the eyebolt with high shear strength that bolts into the oem lap seat belt location on outside? I know it is an M10 1.25 eye bolt. But pretty sure buying one at home depot won't be safe lol.
