Motons for Stock
Old Jan 10, 2012 | 02:04 PM
Apeatwo's Avatar
Default Motons for Stock
I currently have the SOS Moton setup with spherical top hats and springs, which is great for STR, but my plan is to run BS. What is everyone doing for lower spring perches? I've searched and found the threads with mounting and STR related spring posts but nothing on perches. SOS has no recommendation other than to search the forums and "I heard somebody was doing something".
I can design some and have them fabricated but I don't want to go through the trouble if there is an existing solution.
While I'm at it, my interpretation of the rules suggests the spherical top mounts are stock class legal. Is my thinking correct? If I can, is it even possible with the spring perch height requirement?
Thanks for your help.
Old Jan 10, 2012 | 02:07 PM
josh7owens's Avatar
I would pm Marc P or Jay. They would know. Jay has motons on his CR
Old Jan 10, 2012 | 02:11 PM
Apeatwo's Avatar
Thanks, I've sent a message to Jay and hope to hear back soon. Those two are definitely a wealth of information.
Old Jan 10, 2012 | 03:05 PM
glagola1's Avatar
What you do is flip over the lower spring perch that is on the Moton so that there is a flat resting area for the stock lower perch to rest on. Take a rubber mallet or hammer if you like, to the stock perch on the stock shock. Smack that bastard on opposite side until if pops off. Slide it down over the Moton body which is only a few mm more narrow than the stock shock body and sit it on the upside down (flat side) perch. Measure the stock shock from center of the clevis bolt hole (mounting fork) to the bottom of the stock spring perch. Match this on the Moton.
Profit.
Old Jan 10, 2012 | 03:09 PM
sirbunz's Avatar
Profit.
+1
No need to disturb Jay, he's probably on a beach in Jamaica staring at his SCCA calendar!
-Marc
Old Jan 10, 2012 | 05:18 PM
PedalFaster's Avatar
This guy's selling a more elegant solution if you're so inclined: https://www.s2ki.com/s2000/topic/874...#entry20660123
Hard to justify even the $300 he's asking if just flipping the collars that come with the shocks works, though.
Old Jan 10, 2012 | 05:25 PM
//steve\\'s Avatar
Here is a pic of an AST setup using the OEM lower perch. I imagine you do the exact same thing for the Motons.
Old Jan 10, 2012 | 10:21 PM
modMonkey's Avatar
^ +1. For the setup that I was sold, that's what the original owner did.
Old Jan 11, 2012 | 05:45 AM
Apeatwo's Avatar
Profit.
Awesome, Thanks Matt! and everybody else. This is exactly what I was looking for. Now I just to find a cheap OEM suspension and I'll be ready to go. I don't want to take my stock assembly apart.
Old Jan 11, 2012 | 06:02 AM
glagola1's Avatar
Originally Posted by Apeatwo
Profit.
Why not? You can easily reassemble it. And you're welcome.
