Mounting 6point question on right side point
Just bought a seat, a GFL bar and getting my 6-point belt soon.
I understand I should drill the floor and be careful about the fuel lines for the ASM straps. Use the harness bar for the shoulder belts and the for the left lap belt use the stock belt location.
What about the right lap belt? I think I read on here someone mentioning the transmission tunnel as a mount point, but do you have to drop the transmission to get the hardware and a backing plate in there?
Is there an easier location?
There's no other possible location.
usually there is a mounting point on the seat base for the right side of the lap belt. But if you dont have a mounting point, just mount it to the chassis at the correct angle. I know the sparco website has the correct mounting angles for the lap belts and shoulder belts.
Here is the PDF from sparco: http://www.sparcousa.com/resourceFiles/16.pdf
lift the car so you can see where you'll be drilling - you're looking for enough space on the tunnel wall for the backing steel plate. drill from inside being careful not to hit the shaft on the other side (about 2 inches away)
a dremel made the shaping of the hole much easier.
Originally Posted by tinkfist' date='Mar 15 2007, 06:42 AM
Where are you drilling the ASM holes in relation to the stock seat's front bolt holes? Can you not reuse those holes?
Originally Posted by mikegarrison' date='Mar 15 2007, 12:57 PM
ASM straps should actually attach below your butt for a six-point. Nowhere near the front of the seat. For a five-point, the attachment point is supposed to be forward.
Originally Posted by tinkfist' date='Mar 15 2007, 11:06 AM
With that reasoning, would it be optimal to have both ASM straps run under the seat to one bolt directly under you?
Or would two bolts, each at the midpoint and inline with the current front and rear seat bolts, be a better setup?
CoralDoc
Feb 20, 2003 05:30 AM
