Muffler Question
Old Sep 9, 2003 | 12:00 PM
Hyper-X's Avatar
Default Muffler Question
Will changing out just the mufflers (not the exhaust piping) still be legal to be in stock class autocross or will that put me into a different catagory? I'd look it up but I can't find my book.
Old Sep 9, 2003 | 12:14 PM
payneinthe's Avatar
I'm pretty sure you can do anything with the exhaust past the cat. Some national level drivers have dryer venting as their "exhaust" in stock class cars.
Old Sep 9, 2003 | 01:34 PM
CoralDoc's Avatar
No problem, everything after the CAT can be replaced. The exhaust has to exit the vehicle to the rear, so even a straight pipe would be OK if the noise isn't too loud (and it probably would be).
Old Sep 10, 2003 | 07:11 AM
Legal Bill's Avatar
CoralDoc is right. You can do a number of cheap things though. Try cutting a stock system off after the resonator and then just run pipe back to the RH exit. That at least gives you a resonator to quiet it down. You can also put a downward turn at the end of the pipe to send the exhaust noise straight down. If you can find a cheap, used exhaust someone is getting rid of you can keep your stock system intact in the garage or basement and cut up the other one.
AC50
Dec 8, 2016 10:47 PM
WarrenW
Aug 13, 2011 05:52 PM
b18-Mike
Jun 25, 2007 06:41 AM
SilverKnight
Aug 16, 2005 08:05 PM
mbitton
Aug 12, 2003 08:10 AM
