New Enkei PF01 18x10.5 +47 track worthy?
Old 01-17-2013, 07:23 PM
Cooper4x's Avatar
Default New Enkei PF01 18x10.5 +47 track worthy?
Maybe another option for some, of course tires will cost more then 17's...
http://store.outperformance.com/Prod...60-8105-6547BK
Old 01-18-2013, 07:21 AM
Former Sponsor
GT Motoring's Avatar
Thats quite large to fit on an S2000 without a lot of fender work.
Old 01-18-2013, 07:34 AM
chrisaltima's Avatar
Offset is good but you need something more in the 9-9.5 neighboorhood...10.5 is tremendous as you would need to wrap a 265 around it at least...I would pass
Old 01-18-2013, 09:39 AM
CKit's Avatar
Needs much higher offset, I'd think.
Old 01-18-2013, 04:44 PM
JJ7
JJ7's Avatar
It would just require an aggressive roll/ pull to run 265s. You would have 2mm more clearance than me with 10mm wider tires.
Old 01-18-2013, 05:35 PM
CKit's Avatar
10.5 is overkill to run 265s. Dunlop's Direzza Z2 now comes in a 285...
Old 01-20-2013, 08:14 PM
Cooper4x's Avatar
I'm running 17x10 +38 right now 255 all around on the track. stock fenders heavy roll and pull. this would actually be 3mm "tucked in then what I currently have. 15mm wider on the inside. would be sweet to see some 285's all around...
Old 01-21-2013, 04:06 PM
CKit's Avatar
You can fit a 315 on a 18x11 rear with 8.5" backspacing with just a roll and mild flare.
Old 01-22-2013, 10:30 AM
clarkster009's Avatar
That does seem like a difficult fit on a stock body. I would think the 18x9.5 +45 would be the better option with 265s. Probably lighter as well.
nrcarone
05-29-2017 06:45 AM
pjf1985
12-15-2013 10:41 AM
pappi16
12-20-2012 07:03 AM
dogzilla
12-18-2007 02:20 PM
Nobody
03-09-2004 04:11 PM
Quick Reply: New Enkei PF01 18x10.5 +47 track worthy?
