NSX (NA1) rear caliper on S2000?
Has anyone heard of running a NSX rear caliper and rear brake rotor on a S2000? I stumbled upon it by reading a Japanese tuner shop's blog via Google Translate. Very interesting website.
http://translate.googleusercontent.com/tra...6DI9MXhtsj-nUnw
It is attached for Riyabikkurotakitto S2000.
This customer is a recent AP Racing front calipers & 330mm rotor fitted, I run the circuit off-balance Shimai the brakes, I could not connect to the set time.
So this is about balance and optimize braking up.
322mm rotor by using the NSX rear calipers, brought up the braking force and controllability. The addition of ventilated, cooling efficiency is greatly improved, distortion, cracks can be minimized.
The brackets, hub ring look to be pretty straight forward. How much does a NSX caliper cost? How much does a brake rotor cost?
If you are up there in that price. Might as well just get the Wilwood Rear brake kit they offer.
Szoylent Green
Jan 11, 2017 06:23 PM
