OBD2 iPhone/Harry's recommendations
Old Nov 26, 2017 | 03:38 PM
bgoetz's Avatar
Default OBD2 iPhone/Harry's recommendations
I asked this question a while back and the answer I got was the BT1 or PLX3. I never pulled the trigger, but I have developed a misfire and flashing CEL, so I need to pull the codes (most likely misfire codes). I figured I would try to get something that will work with Harry's. Has anyone had any luck with the inexpensive ones working or is the BT or PLX my best option? I would like to spend as little on the tool as possible so I can save my $ for the likely coil replacement.
If I didn't want to use it for Harry's could I just do a cheap one? If so any recommendations for that?
Thanks for the help!
Old Nov 26, 2017 | 04:34 PM
s2000ellier's Avatar
I have a cheap $5 BT dongle that works for android I can't imagine there isn't a ios equivalent out there for the same price. When I tried to do data logging with it tho it was only 1hz. I never could figure out how to increase the odb2 throughput although some said you simply reduce the PIDs that are sent but my software didn't support that on the phone.
Old Nov 26, 2017 | 07:37 PM
afzan's Avatar
Not sure if you've seen this but there's a whole section on harrys lap timer website with details on the various options : iOS - Harry's GPS Laptimer
Old Nov 26, 2017 | 08:24 PM
gptoyz's Avatar
Any elm327 wifi will work for both obd2 scanning/clearing and Harry's LapTimer function on an iPhone
Bluetooth didn't work for iPhone but that may have changed
For obd2 functionality I use eobd
Old Nov 27, 2017 | 05:15 AM
bgoetz's Avatar
So something like this should do the trick then?
https://rover.ebay.com/rover/0/0/0?m...2F152257530439
Old Nov 27, 2017 | 05:37 AM
if you got amazon prime i'd suggest buying there to enjoy the no hassle returns
its even cheaper
Amazon Amazon
Old Nov 27, 2017 | 05:58 AM
bgoetz's Avatar
its even cheaper
https://www.amazon.com/Veepeak-Scann.../dp/B00WPW6BAE
Thanks! I ordered it, we will see how well it works!
Old Nov 27, 2017 | 05:13 PM
warmmilk's Avatar
bluetooth works for iphone, I've been using my PLX Kiwi3 via bluetooth all of last year with HLT
Old Dec 9, 2017 | 09:42 AM
bgoetz's Avatar
Well the performance feature is basically worthless l, it doesn't refresh fast enough to provide anything useful.
bgoetz
Oct 26, 2016 12:36 PM
Thateguhate
24
Mar 28, 2013 06:21 PM
caboose
Nov 27, 2012 01:35 AM
mrsir85
Jun 25, 2010 06:22 PM
What The
19
Jan 20, 2009 11:01 AM
