ohlins 12/10 what shock setting?
In regards to not setting too stiff, when you go beyond a certain point the shock response starts to become non-linear, meaning the amount of damping resistance might not be same in a repeated moment of movement direction and velocity, because whatever the shock was doing immediately PRIOR to that moment starts to have carryover effects. So going from rest to extension might not have the same damping as going directly from compression to extension even if the extension velocity is the same. Taken to the extreme, that starts to lead to unpredictable grip over bumps and comfort issues.
I would experiment with settings until you find a setting you like. I like to have the rear at a lower setting than front because it helps stabilize the rear under hard braking (the rebound increases more than compression as you go stiffer). The sweet spot for my driving style was like 6-4 or 5-3.
And if you are running right at the stiffest setting, you may find you have improper valving for the application and a revalve may be in order.
My experience when testing damper settings also coincides with the other poster that said the rear damping changes have more of an effect on the chassis characteristics than the front damping changes.
problem_child
Oct 14, 2008 06:23 PM
