overheating on track
Only one other person had mentioned it... Your coolant. I would suggest 20/80 mix. 20 coolant, 80 water. The coolant should be in the system for nothing more than corrosion resistance only. Suggestions from Texas 105F/41c ambient temps with 70-80% humidity at 700ft above sea level. If your temps do not come down after trying that, I would think layout change like Vmount setup would be your next bet... but water is cheaper and you should try it first
Hopefully the new radiator should also be in in a couple of weeks but trying this out first with the old one to check the difference.
Waht would the corrosion effect be when using so much distilled water?
The thought is that you use a small amount of coolant. I run around 20% on my street cars, but I am in Florida.
There are also additives such as Motul Mocool though I honestly think they are the same thing as coolant but with more surfactants. I haven't been able to fund much info on them though a lot of people claim they work really well with just distilled water.
I think most corrosion problems arise from people using tap water.
Over the years of racing I've seen Water Wetter solve numerous showroom stock cars overheating issues. One that comes to mind was a Cobalt that would not over heat but get hot enough to pull timing like crazy about 3-4 laps into the race. Owner told me that it never happened when he raced in cooler weather up north. This was an SCCA double so he poured water wetter in it saturday night and sunday's race he beat all of us cause it never got slow on him. Bad advice on my part.
Basically, traditional antifreeze is great for it's name (i.e. providing a lower freezing point). However, it does't dissipate heat as well as water. Therefore, running a higher mixture of water with traditional antifreeze will give you better cooling than 100% antifreeze (as it will make the radiator more effective). You should run the lowest amount of antifreeze mixture per water needed for your climate to maximize your cars cooling capabilities.
I had a twin pass rad made in the uk and it sorted all my track temps. I see a max of 93c then once the fans start it pulls it down to 87-88c then keeps doing that cycle. Oil gets to 110c for reference. This is while doing about a 20 minute track session.
What power were you making?
