Power Loss Under Cornering
Old Dec 28, 2018 | 04:54 PM
samsam5886's Avatar
Default Power Loss Under Cornering
The power loss happens 11:00 minutes into the video and several times again through Riverside at 12:50
My first guess was fuel starvation after it happened in the previous session with less than 1/4 tank, but it continued happening after filling to 1/2 tank. It was perfectly fine in the beginning of the day. Or it could be oil related.
Does anyone know what might be causing it or has anyone managed to fix a similar issue?
Old Dec 29, 2018 | 04:16 AM
summitrider2012's Avatar
my only thought is maybe something wrong with the pump or maybe a loose wire/connector or relay. can you data log?
Old Dec 29, 2018 | 05:24 AM
stooga's Avatar
Banned
I've gotten fuel starvation at close to 1/2 tank. It's worth seeing if it still occurs at a full tank
Old Dec 29, 2018 | 11:18 AM
RAIN H8R's Avatar
Do you have a baffled oil pan? Do you have the valve cover mod done?
Old Dec 29, 2018 | 12:20 PM
samsam5886's Avatar
Hm yea it could be. Could driving with less than 1/4 tank in the previous session have done some sort of damage related to the fuel pump? Unfortunately I can't data log. Wiring is a good possibility too, but it feels more fluid related though since there are some other high G turns where nothing happens.
Yea that was right below 1/2 tank. I will try again with a full tank next time I should have tried it with full tank on that same day >_<
No baffled oil pan (but planned! lol) but it has never been an issue for the past 14 track days. I've heard our cars lose VTEC when oil pressure reaches below a certain point, is that right? What is the valve cover mod? Is it related to blow-by? It definitely could be oil related too because I was 0.8 quart low from the H mark on my dipstick when I got home.
Thanks everyone!
Old Dec 29, 2018 | 05:40 PM
Bullwings's Avatar
What session number? I definitely need to keep it above half tank to make sure I don't get fuel cut. The s2000 gauge is very inaccurate for track use. If your tank said half, it most likely was less than half. I'm finding that I'm adding +8 gallons at the half way mark when read during track use (it's a 13.2gal tank).
If I get low traffic and a clean full 25 min session for 1 and 2, I definitely need to fill up before the 3rd session.
Old Dec 29, 2018 | 07:59 PM
AZS2KDancer's Avatar
I just picked up my new oil pan that I had a baffle welded into. I plan to install it in the next month or two. What is the valve cover modification? I'm also planning a dual catch can install.
Old Dec 29, 2018 | 08:46 PM
HawkeyeGeoff's Avatar
https://www.s2ki.com/forums/s2000-ra...ation-1133707/
^VC mod.
Old Dec 30, 2018 | 02:09 AM
samsam5886's Avatar
Wow very neat VC mod! Thanks Hawkeye
Bullwings, the power loss happened in session 3 and it read 1/4 tank on track and empty with gas light on by the time I got to the paddock lol so yea it does read much higher on track with it sloshing around.
Old Jan 2, 2019 | 12:57 PM
the-moss's Avatar
I think this is fuel starve, you have the classic left hander shortly before it happens. On my car I fuel starve after left handers after I'm only 5 gallons from full.
There's a 'damper' on the factory fuel gauge that prevents it from responding quickly to fuel slosh, when tracking this means the gauge won't go down as quickly as you're actually using fuel. See below for my undamped data log of actual fuel level for a lap. Drops from 100% to below 70% just from slosh.
