Power Loss Under Cornering
Old Jan 18, 2019 | 05:53 PM
RAIN H8R's Avatar
Originally Posted by samsam5886
Hm yea it could be. Could driving with less than 1/4 tank in the previous session have done some sort of damage related to the fuel pump? Unfortunately I can't data log. Wiring is a good possibility too, but it feels more fluid related though since there are some other high G turns where nothing happens.
Yea that was right below 1/2 tank. I will try again with a full tank next time I should have tried it with full tank on that same day >_<
No baffled oil pan (but planned! lol) but it has never been an issue for the past 14 track days. I've heard our cars lose VTEC when oil pressure reaches below a certain point, is that right? What is the valve cover mod? Is it related to blow-by? It definitely could be oil related too because I was 0.8 quart low from the H mark on my dipstick when I got home.
Thanks everyone!
Sorry I am late to reply. If you are low on oil I suspect you need your valve cover modified.
Old Sep 1, 2019 | 12:41 AM
altimatic's Avatar
If you are experiencing fuel starvation on left hand turns, I replaced my fuel filter and sock with a new oem unit as long as install the fuel tank baffle.
Solved my problem
Old Sep 1, 2019 | 11:32 AM
miamirice's Avatar
I went through this on an s2000 and it was a lose wire where the ECU was ziptied to the cage by the clutch/footwell area. Frustrating
Mezza
Feb 3, 2013 09:32 PM
kleecker
Feb 7, 2012 05:12 PM
Heinz '57
Car Talk - Non S2000
16
Aug 26, 2011 04:52 AM
