Questions about Wheel spacers...Alignment ?
Old Dec 10, 2006 | 08:53 AM
bc02's Avatar
Default Questions about Wheel spacers...Alignment ?
I am currently installing a Brembo GT Brake kit on my 18 in. Volk TE 37's +48 offset front......and had to order H&R 15mm wheel spacers to clear the calipers and now have the longer studs installed and ready to go.....my questions are 1st do i have to widen the rear track also because what is the car going to handle like now with the front track being 30mm wider than the rear track??? and also what is this going to do to my alignment and does anyone know what specs i should start out with when i get it aligned?? Thanks for any help
Old Dec 10, 2006 | 09:34 AM
WindchaserS2K's Avatar
question your fender will clear with the 15mm Spacer????????
Old Dec 10, 2006 | 11:58 AM
bc02's Avatar
That i am going to have to find out ........if it doesn't i will have the spacers milled down at a machine shop to the exact spec i need for the caliper/wheel clearance......the 5mm spacer wasn't enough so i had to buy the 15mm ones and it seems a bit too much...what a pain in the ass this Brembo GT kit has been.....i had no idea that my offset Volks wouldn't even clear them!! But now my concern is getting the right alignment.....and whats it going to handle like being that the spacers are on the front track and not the rear?? Any one out there running Brembo Grand Turismos that had similar problems??
Old Dec 10, 2006 | 08:54 PM
Ustemuf's Avatar
i have a brembo gt kit but i have prodrive gc07cs 17x7.5 with +48 offset.. i have about 5 mm clearance with this setup.. i looked into wheels carefully before buying knowing that i would be upgrading the brakes. spoke design plays a big role in bbk fitment.
Old Dec 11, 2006 | 04:53 AM
blackey's Avatar
The spacers should not affect alignment. Handling is another story. Widening out the front track will make a nuetral car oversteer.
Old Dec 11, 2006 | 04:29 PM
bc02's Avatar
How much do you think it will make the car oversteer...because i have a Comptech Competition front sway bar which is 5-way adjustable and i have it 200% stiffer right on the middle setting which eliminated the stock oversteer problem the S is known for and it is currently nuetral.....the max it will go is 280% stiffer on the last of the 5 settings.....would that be enough?? THANKS for the info
Old Dec 12, 2006 | 07:29 AM
blackey's Avatar
I'm positive it will NOT change it that much. Maybe one position on the swaybar if that.
bobby.is.rad
Jul 23, 2014 06:07 PM
David_T
Aug 22, 2009 02:28 PM
mph2k
Mar 17, 2009 10:49 AM
j66
Jan 25, 2007 08:23 AM
docofmind
Aug 12, 2003 10:58 AM
