Race seats
Old Mar 19, 2015 | 07:48 AM
  #371
Arro's Avatar
Here are a couple pics of my OMP's. PM me if you want specifics.
[attachment=75628:IMG_2032 (Large).JPG]
[attachment=75629:IMG_2050 (Large).JPG]
Attached Thumbnails Race seats-img_2032-large-.jpg   Race seats-img_2050-large-.jpg
Old Mar 19, 2015 | 08:09 AM
  #372
manolo1492's Avatar
The Evo 2 non US is a sweet seat!! Prob the widest you can squeeze in the s2k, I sit all the way back and removed the rear interior panels, otherwise it would rub HARD. I decided to go with the fighter for slightly better fit in the car so my brand new Evo 2 is listed for sale here
Old Mar 19, 2015 | 07:15 PM
  #373
bdo's Avatar
bdo
Originally Posted by duffman13
Originally Posted by bdo' timestamp='1426714151' post='23545443
[quote name='duffman13' timestamp='1426698683' post='23545088']
[quote name='jamesac83' timestamp='1426698163' post='23545074']
[quote name='TwoRs' timestamp='1426638158' post='23544234']
Talked with Sparco tech support today and he indicated the EVO II will fit, the EVO II US would be to wide for the S.
Research continues, keep it coming!
I just put an Evo II in my car a couple weeks back, the bottom is so wide toward the front of the seat that I couldn't imagine the Evo II US would fit at all unless its just wider in the hip area and just about nowhere else. I couldn't imagine putting a seat bigger than the Evo II in the S unless there is no interior in the car,
I actually had an Evo in my car previously, and even that was a stretch in the seat base and shoulder wing areas.
I know it's not FIA certified, but the Corbeau FX1 Pros I have now fit great, have more hip room than the sparcos with the same footprint, and have less intrusive shoulder wings. They do have a mounting post for a seat back brace though, so you can use that in lieu of the FIA cert in most organizations.
[/quote]
Do you think the FX1 (non-pro, next size up from the Pro) would fit?
[/quote]
I doubt it, there's basically no hip room left with the Pro in. That said. I'm no tthe smallest guy at 5'9 185, 34" waist and I do a lot of lifting so I have good sized thighs and glutes. I fit in the Pros with room to spare.
If you fit in an S2000 seat normally, the Pros should fit you fine; you'd have to be really big to need the standard FX-1, let alone the FX-1 wide. I sat in a standard once a couple years ago when I was about 10lbs heavier and 2" bigger waist and I was swimming in it.
[/quote]
Great info, thanks!
Old Mar 20, 2015 | 07:58 AM
  #374
//steve\\'s Avatar
Which OMP seats are those and what would say is the max waist size for each? And what rails are they mounted on?
Old Mar 20, 2015 | 08:15 AM
  #375
Arro's Avatar
Driver = HTE-R 400 (just like HTE-R but with narrower external halo width - so there wouldn't be any soft frame or window interference)
Passenger = ARS-R
Mounted on Buddy club rails. Seats feel like they are at OEM height.
I have a decent write up if you want to PM me your email address.
My dims = 6' tall 38" waist 32" inseam
Old Mar 20, 2015 | 08:17 AM
  #376
Arro's Avatar
I found during my research the sparco EVO series flare out quite a bit on the bottom at the front. When I was looking for seats, I had the opportunity to personally measure the Evo, EVO 2, and Evo 2 US. I also measured the Buddy Club Racing Spec (wide), and of course the OMP ARS-R and HTE-R 400. I have the dimensions at home but IIRC, the Evo seat starts at 20" wide max width at the front and increases by 1/2" for every step up in size in the Evo series. So Evo 2 would be 20.5" and the Evo 2 US would be 21". The Evo 2 would have worked OK for me, but was a little snug through my hip area. I had the opportunity to try out the OMP's and they were perfect. The ARS-R is actually 20.25" max width across the front so it is narrower than the Evo 2, but has more interior width by my account.
So to sum up, I agree that the Evo 2 may be at the max width to fit into the S2K. But as Boyguan said earlier (and I paraphrase), due to different seat designs, the max external width seat does not necessarily have the max internal width. While the OMP seats have the lip on the outside, I don't think that is unique to OMP because the Sparcos have it too. I think OMP does a good job of maximizing internal width given the extrnal dimensions of the seat.
If anyone needs some dimensions as taking from an actual seat listed above, PM me.
Old Mar 20, 2015 | 08:31 AM
  #377
Mahjik's Avatar
Originally Posted by yamahaSHO
I picked up a Recaro SPG last year and installed it over this winter with Ballade rails. I look forward to trying it out on track next month when the tracks open back up.
That looks really good! And I'm not just saying that because I know you.
Old Mar 20, 2015 | 11:43 AM
  #378
TwoRs's Avatar
Thanks for all the info!
Old Apr 14, 2015 | 06:33 AM
  #379
GravyRobber's Avatar
I'm definitely in for more information about the FX1 Pros. Car is only used for weekend drives and HPDE...no competition or TT of any sort. I've got a 36" waist and am 6'1". I'm most concerned with sitting as low as possible. I'll be using stock seat belts and OEM hoops. Can anyone comment on how low these seats can be mounted, and on which rails? I understand the provisions for bottom-mounting the seat prevent it from being able to drag the carpet like a pole position, but I'd hope that it would still be significantly lower than stock?
For rails, I was looking at the BC, Nagisa, or the Ballade.
Thanks for any info!
Old Apr 14, 2015 | 06:45 AM
  #380
yamahaSHO's Avatar
Haha, thank you. I've driven it on the street a few times... I can tell I put on a few beer pounds over winter.
