Raking the S2000 - An Idea for Putting Down Power
He doesn't need to run a huge rear bar with those rates... I actually looked up the rate on an AP1 rear bar (427 lbs/in), which would explain a lot. I'm 15k/11k and run a little bit lighter than a Miata rear bar (179lb).
What are you doing for bumpsteer? The AP1 bumpsteer geometry is very severe in the rear, so you can end up chasing your tail on the rear on transient events due to the rear bumpsteer being all over the place.
Thank you again all that are sharing!
That spreadsheet looks interesting
The very strong rumor is that TTC is going away for TT4/5 next year. My advice would be to get sway bars to fix the issue and not worry about points.
TTC is going to end up split across TT4 and TT5, with the idea of TTD cars being able to slot into TT5.
dsddcd (11-15-2017)
Yes you are correct, I am chasing points so I chose springs to give an equivalent motion ratio given the chosen front spring rate. I derived those rates based on information Rob Robinette published and my own R&D. Here is a small portion of the overview page. The front spring rate was chosen by consulting others with winning cars and my own experiences leaving on the rear spring to tune the bias. Note I run the car heavy 2900# so I needed a bit more spring than others might normally choose with a stripped car.
I had the same issues on corner exit. Vtec Crossover didn't help either, but what did help me the most was disconnecting the rear sway entirely. I recently switched to a higher sprung setup from my Ohlins and it only got better. I feel it's more of a ratio f/r than a largr lbs/in game.
