remount tire?
Old Aug 9, 2013 | 03:19 PM
ndogg's Avatar
Default remount tire?
I did a bit of off-roading last weekend. There was a good amount of weeds that got jammed in the bead of a tire. The tire has not lost any air but I don't know if I need to get it remounted or if it is still safe to run. Check out the pic, you can see the bead is a little deformed. What do you think?
Old Aug 9, 2013 | 03:44 PM
recnelis's Avatar
Well if you have to ask, remounting is going to be way cheaper than an accident at speed. It also gives you a chance to inspect the wheel up close in case it was damaged in your off.
Old Aug 9, 2013 | 04:01 PM
andrewhake's Avatar
Remounting is cheap. If the tire still has plenty of life I definitely would.
Old Aug 9, 2013 | 04:11 PM
jaundice's Avatar
Most grid captains would not let you run it like that anyway. Needs to be deflated and all debris cleaned out and remounted.
Old Aug 9, 2013 | 04:23 PM
ndogg's Avatar
Ok that's what I was figuring. I'll take it in and get it fixed up. Thanks.
project2k4
Sep 13, 2012 08:22 AM
deepbluejh
Dec 28, 2010 11:59 AM
Optikal
Oct 27, 2004 08:17 AM
efthimios
Jun 10, 2004 11:11 AM
F20C
Aug 2, 2001 03:42 PM
