Removing the softtop
Hello R&C.
I remember a while ago speaking with a fellow s2ki member at a local track day about removing my softtop and running only the hardtop for weight savings. I was told that in doing so you compromise chassis rigidity because the soft top helps stiffen everything a bit. Is this true? He said the CR uses reinforcement bars to compensate for the lack of a softtop, a honeycomb type of bar? Would I need to purchase that if I removed my softtop? I've seen plenty of people running a hardtop only and tracking just fine, I need to know what the concerns are over this.
The rest of the car is pretty much stock, I only have the hardtop and want to shed some weight off the car. The trunk is pretty much gutted and the softtop is the last bit I want to do, the car is still a street car and not a full track car, so I must keep the rest of the interior.
Please don't turn this into a weight savings thread or a utility thread. I am only asking if removing the softtop is going to hurt performance and if so, what can I do to fix it? Adding bracing? (I'd rather not add bracing as that is pointless to remove weight then add more on -_-, plus I question whether bracing does anything on certain cars)
Thanks for any information in advance.
Given that I was able to re-shape the frame by hand after it got tweaked blowing open during an autocross run, I don't think it provides and significant stiffening.
Consider the fact that I can place the car on four jack stands and the car will only rest on three of them because my floor isn't quite flat. That's a rigid chassis.
The softtop motors do form part of the load path between the two sides of the car, IIRC. That means that removing them probably would change the stiffness a little bit. The question is whether it would be significant. I doubt it.
