Rollbar options?
Old Mar 5, 2007 | 05:27 AM
  #21
fperra's Avatar
Originally Posted by geists2k,Mar 5 2007, 06:12 AM
And with only 1.5" X .125" DOM steel it's not NHRA legal either.
Doesn't matter, because with the power I'm putting down NHRA wouldn't let me run without a full cage.
Old Mar 5, 2007 | 05:43 AM
  #22
geists2k's Avatar
I'm close...
The new rules for 2007 are anything 11.49 or quicker requires a 1.75 OD 5 point bar or better.
Old Mar 5, 2007 | 10:17 AM
  #23
Ludedude's Avatar
Administrator
Originally Posted by 3312DC,Mar 4 2007, 05:27 AM
wow... impressive.
for once someone puts the harness bar in the right place.
It's easy to put the bar in the right place if you're willing to make compromises on how (or if) the interior goes back together.
Old Mar 5, 2007 | 10:22 AM
  #24
rlaifatt's Avatar
I'm not sure if I like that curve in the harness bar right where the outer shoulder belt would attach. Seems the belt could slip forward in a violent crash, unless a ring clamp or something is attached also to prevent this.
edit: on second look, doesn't seem that this would happen in a crash, but seems you would always have to make sure the belt is on the straight part of the bar (to keep both belts close and centered, especially for HANS) before locking in, so I'd still use a ring clamp to prevent this movement.
Old Mar 5, 2007 | 10:40 AM
  #25
fperra's Avatar
If you are talking about mine, the shoulder line up perfectly, and, in addition, ring clamps keep them alligned.
Old Mar 5, 2007 | 12:16 PM
  #26
ZDan's Avatar
Originally Posted by SC_Highlander,Mar 5 2007, 05:58 AM
Without a diagonal it won't be SCCA leagal for autocross either.
I thought a roll bar wasn't even required for SCCA autoX.
Are you legal with no bar, but illegal with a bar without a diagonal?
Old Mar 5, 2007 | 12:18 PM
  #27
mikegarrison's Avatar
Yup. You are legal with no bar in most classes, but if you have a bar it has to meet specs. Or maybe that's just if you have harnesses then the bar needs to meet specs?
Anyway, just look up the GCRs.
Old Mar 5, 2007 | 04:22 PM
  #28
SC_Highlander's Avatar
Correct. If you run harnesses in a convertible, it must have a bar that meets the GCR specs. If you're not running harnesses, then no bar is required.
Old Mar 5, 2007 | 05:05 PM
  #29
ZDan's Avatar
So if I'm *not* running harnesses, I can run with a roll bar that doesn't have a diagonal, no?
Old Mar 5, 2007 | 05:24 PM
  #30
Look it up in the GCRs.
