Rolling resistance
Old Feb 7, 2008 | 06:35 PM
ShocK's Avatar
Default Rolling resistance
So what are most of you doing to lower your rolling resistance? Does rim size have an effect here?
Old Feb 8, 2008 | 12:13 AM
sspicollo8's Avatar
what exactly are you talkin about by "lowering rolling resistance?" aerodynamic rolling resistance equals drag. other than that, rolling resistance is caused by toe settings, wider tires, bad wheel bearings, drivetrain friction, etc.
Old Feb 8, 2008 | 07:25 AM
krazik's Avatar
Administrator
I like to run 4 spare tires.
Old Feb 8, 2008 | 07:51 AM
cuonice's Avatar
Non-staggered?
Old Feb 8, 2008 | 08:25 AM
Hobbs5313's Avatar
Originally Posted by cuonice,Feb 8 2008, 11:51 AM
Non-staggered?
Only if you run a BAUW with it.
Old Feb 8, 2008 | 09:07 AM
nemesisssssss's Avatar
try a voltage stabilizer for your wheel speed sensors. also, i heard that if you put a drop of the drift king's gizzum in your differential it's teh equivalent of gaining 20hp
hahaha, just joking. you could try greasing the wheel bearings though... there's a zirc fitting on the hub.
Old Feb 8, 2008 | 09:09 AM
INTJ's Avatar
You can get a hartop and run consumer high efficiency tires. I'm not sure why you would though. The low hysteresis tires suck at handling.
Old Feb 8, 2008 | 09:23 AM
phoenixR34's Avatar
good idea, but you'll lower your RR if you run Honda Prelude spares.. they're 2lbs lighter.
Old Feb 8, 2008 | 09:24 AM
krazik's Avatar
Administrator
what about the nsx plastic spare?
Old Feb 8, 2008 | 11:32 AM
cuonice's Avatar
Hmmm... I like where your head's at!
