View Poll Results: Rotor assembly screws?
Nope...ditch them!
25
56.82%
Yep, they have a purpose!
19
43.18%
Voters: 44. You may not vote on this poll
Old Oct 12, 2017 | 09:06 AM
RedCelica's Avatar
Originally Posted by Topplayer
I like them, why not? With proper tools I have never had one seize.
My "proper tool" over this past weekend was a cordless dremel with a grinding wheel
Old Oct 12, 2017 | 11:54 AM
DanielB's Avatar
I wish there was a middle choice: "Yep, not required, but nice to have"
Like a few others, I like that it makes loading the pads simpler, especially if you don't have the spring metal assy on the rear anymore (forget what it's called). But I alway snug them down and then back out 1/8 turn. Holds the rotor well enough to keep the pads in and still have never had a problem removing one. And I swap street to track to street brakes for every track day - probably more than 50 rounds in the last 2.5 years.
Old Oct 12, 2017 | 12:51 PM
Chibo's Avatar
I use them, but I don't have issues since I live in Arizona.
I only swap front pads for trackdays.
Old Oct 12, 2017 | 01:35 PM
charlesardolino8's Avatar
I thought we discussed this already lol
Old Oct 12, 2017 | 02:23 PM
InsaneSp's Avatar
Do I even need to vote?
Old Oct 13, 2017 | 04:47 AM
King Tut's Avatar
Your vote should be I installed them 3 years ago and I haven't been able to get them off since so I just keep using the same rotors and just put new pads in when they wear out.
Old Oct 13, 2017 | 11:16 AM
dc2-2-ap1's Avatar
Are they needed, no. Do I still use them, yes. They come out real easy with an impact screwdriver and a light tap with a decent sized hammer. But I remove them regularly when swapping pads/rotors from street to track setup, so they don't have much time to seize.
Old Oct 13, 2017 | 11:28 AM
V6 Donut's Avatar
I don't have mine in. left them behind like I left Tut.
Bye Felicia
Old Oct 13, 2017 | 04:26 PM
pmptx's Avatar
Originally Posted by RacerZook
If you're needing something to hold the rotor in place, 2 lug nuts work just fine.
Amen. I had to use an impact screwdriver to get them out. Now every honda I own gets them removed ASAP.
Lugs work fine to hold the rotor.
Old Oct 13, 2017 | 09:32 PM
djsilverjohnson's Avatar
When I changed rotors on my '03 this summer, I used a manual hammer impact and broke 2 tips. I ended up drilling the heads out and the rest of the screws came out by hand after I removed the rotors. I guess I'm a slow learner because I put new ones in after I bathed them in anti-seize.
