Sakebomb Garage Wilwood Track-Day Brake System Review
Old 11-17-2017, 06:53 PM
  #61
DanielB's Avatar
What is the cost of replacement rotor rings? I couldn't find them on the website.
Old 02-20-2018, 03:36 PM
  #62
tut4u2's Avatar
So I have had the kit for close to a year and I thought it would be apt to post an update on the kit. I ended up replacing the pads after 24 sessions from DTC-30 to DTC-50 in the front and HT-10 in the rear. This eliminated all brake shuddering I was experiencing and the car simply brakes better. I don't run any ducting and haven't experienced any fade whatsoever. I could've probably done another 4 sessions on the rear pads and 8 sessions on the fronts, but I decided to replace them together. The rear rings still look mint, and there's so micro-cracking on the front but nothing that catches the nail yet. The rear kit seems drag slightly for some reason. I have tried a couple of sets of calipers, including a remaned set and I have had the same issue. Pictures below:
Front Pads
Front Rings
Rear Pads and Rings
Old 02-20-2018, 03:56 PM
  #63
Chibo's Avatar
What tires and tracks are you running?
Old 02-20-2018, 04:11 PM
  #64
tut4u2's Avatar
Homestead and PBIR in South Florida. I'm running a square setup using 595 RSRR in 255/40/17.
Old 02-20-2018, 05:06 PM
  #65
BradtheMachine's Avatar
I have 400-450 track miles on my front/rear set-up.
DTC60 x 4
R888 245/255
No ducting at all.
Zero fade and will be starting off the season with everything intact. Just took apart to inspect and back together (Sorry no pics). I will be running different tires this season but look forward to more great braking all season long!
Old 02-21-2018, 07:16 AM
  #66
DanielB's Avatar
Have any of you been given a price from SBG for replacement front rings? I've asked but never received a reply.
Old 02-21-2018, 08:07 AM
  #67
toplessPolak's Avatar
Is there a thread/list with wheels and specs that clear this bbk?
Old 02-21-2018, 03:08 PM
  #68
AP floating- $245
SBG standard- $145
Will fit the same as AP caliper if that helps.
Old 02-22-2018, 06:21 AM
  #69
Originally Posted by BradtheMachine
AP floating- $245
SBG standard- $145
Was there a list for that as wel? Couldn’t find it
Old 02-22-2018, 07:09 AM
  #70
Not too sure but here is a template to use
http://www.sakebombgarage.com/conten...20Template.PDF
Quick Reply: Sakebomb Garage Wilwood Track-Day Brake System Review
