Set-up help
Old Aug 15, 2008 | 01:22 AM
ee8's Avatar
ee8
Originally Posted by Sebring AP1,Aug 15 2008, 01:20 AM
Im willing to guess its probably tire pressure or the front and rear stiffness settings aren't properly set for a neutral feeling.
Always start small before you go adjusting large things, things are that's the exact root of the problem.
What are your normal hot tire pressures on the track?
36 Psi front and rear as stated in my first post
Old Aug 15, 2008 | 10:30 AM
jeffjanzen's Avatar
Is this for autox or track? Sounds like track, but you didn't mention it.
Don't put a ton of stock into your shock 'clicks'. Chances are they are not linear, so 4 clicks might do a lot, or it might do nothing at all. Or it might even make them stiffer when it says it's going softer. Unless you've had them on a dyno and tested them through their entire range, you really don't know how well their adjustments work.
I'd start with more static camber up front for sure, and you can even try reducing your rear toe-in to help it rotate, but make one change at a time until you're happy.
You didn't mention changing tire size as an option, but when that time comes, consider wider fronts.
Old Aug 15, 2008 | 10:51 AM
ShocK's Avatar
I say -2.0 degree camber up front and loose a couple clicks in the rear, just what I would try personally.
Old Aug 15, 2008 | 11:00 AM
ee8's Avatar
ee8
Yes it
Old Aug 15, 2008 | 11:07 AM
ee8's Avatar
ee8
Humm... softer in the rear? would you like to elaboarte on that a bit... cause most of the guys tend to steer me into the softer front direction?
Old Aug 15, 2008 | 11:14 AM
ShocK's Avatar
Sorry, missed your dampening settings, looks like you already have it set a couple clicks softer than front. Is there a recommended track setting for this damper? Its always easier to start there.
Are you running stock sways?
You do have a lot less tire up front, more of a stagger than stock for an AP1, but you may be able to tune it out. 225's up front would have been nice.
My AP1 handled really well with 32psi hot tire pressure on RE01R's
Old Aug 15, 2008 | 12:35 PM
ee8's Avatar
ee8
Yes... stock sways. I don
Jmpu671
Dec 9, 2015 12:13 PM
CKit
Nov 26, 2008 09:56 AM
David_T
Sep 15, 2008 11:28 AM
RIDGERCR
18
Apr 28, 2008 07:24 AM
patastinky
31
Mar 3, 2008 09:12 PM
