Setup advice
Current setup...
Huge wing
KWv3 with original springs
Stock '03 front and rear sway bars
-3.5 front camber, -3 rear
225/255 NT01
It pushes everywhere.
Plan for next weekend:
Eibach front sway bar, factory '03 rear bar
-3.5f camber, -3 rear
255 square NT01
Will I have excessive oversteer? Seems as though most run heavier front springs (compared to rear) and a very large front bar for 255 square.
Huge wing
225/255 NT01
255 square NT01
You're probably right, hence changing to the 255 square setup.
But with 255's, square springs, and "only" an eibach front bar... will it be excessively loose? A little loose is really fun, but I don't want it to be excessive.
Dan, if you're there Sat you've really got to see the holes in the trunk!
Caster is 6.45.
Wing is currently flat.
I figured the soft setting on the eibach is close to stock. The eibach bar only has two positions, but at least that way I have more ability to adjust on site if I don't like the balance.
Caster is 6.45.
