Setup advice
Old Feb 8, 2013 | 08:12 AM
turbo8765's Avatar
Default Setup advice
Current setup...
Huge wing
KWv3 with original springs
Stock '03 front and rear sway bars
-3.5 front camber, -3 rear
225/255 NT01
It pushes everywhere.
Plan for next weekend:
Eibach front sway bar, factory '03 rear bar
-3.5f camber, -3 rear
255 square NT01
Will I have excessive oversteer? Seems as though most run heavier front springs (compared to rear) and a very large front bar for 255 square.
Old Feb 8, 2013 | 08:46 AM
macr88's Avatar
Too much wing maybe?
I'm not sure a wing is needed with 225's
Old Feb 8, 2013 | 09:22 AM
dan_uk's Avatar
stop being a pussy it will be fine
turbo8765's Avatar
You're probably right, hence changing to the 255 square setup.
But with 255's, square springs, and "only" an eibach front bar... will it be excessively loose? A little loose is really fun, but I don't want it to be excessive.
Old Feb 8, 2013 | 09:24 AM
turbo8765's Avatar
trying not to leave you too far behind
Old Feb 8, 2013 | 09:35 AM
dan_uk's Avatar
the size of that wing and assuming the tires are half decent i can't see it being a problem its not going to snap oversteer unless the wing tears the trunk off!
Old Feb 8, 2013 | 09:38 AM
GT Motoring's Avatar
Former Sponsor
Switch to a square setup first, leave the sways as is. If that doesn't work, back the wing down in its AOA.
Whats your caster at?
Old Feb 8, 2013 | 09:50 AM
turbo8765's Avatar
Dan, if you're there Sat you've really got to see the holes in the trunk!
Caster is 6.45.
Wing is currently flat.
I figured the soft setting on the eibach is close to stock. The eibach bar only has two positions, but at least that way I have more ability to adjust on site if I don't like the balance.
Old Feb 8, 2013 | 10:17 AM
CKit's Avatar
Zero rear toe? If too twitchy, can dial a little toe in at the track.
Old Feb 8, 2013 | 10:33 AM
dan_uk's Avatar
yea I'm booked for the PCA event I don't have much tire left i might have to bring A6's but they won't last long either
