Source for KWV3 Compatible Springs?
You would definitely still need the keepers with 6 inch springs and since KWV3s don't have a top preload adjuster you need to run the keepers to keep the ride height adjustable/flexible, but you may be able to find the perfect length spring to run without keepers.
I use swift 12kg, 60mm on my KW Club Sports.
I like the response very much. They feel more consistent and the transient response gives excellent compliance so the increase of 100 lbs over the 570 lbs/inch KW dose not feel any more harsh.
The KW's are 62mm Id and the Swifts fit snug but no problem.
You need to adjust for the spring height difference. KW is 5.5" and Swift is 6". Also easily done.
Where are you guys buying springs from? I am planning on upping the rate on my V3s soon.
With an adapter, do you think running a 2.25" spring is possible? I ask because I can get free 2.25" springs in any rate.
I bought my Eibach springs from summitracing. They are 2.5" and have a little bit of extra clearance, but I don't know if there is enough to clear a 2.25". If you get them free, might as well try. I would start with checking the threaded shaft and dust boot with a caliper.
ClayMan28
05-03-2011 07:27 AM
