Spacer on sway bar bracket
I attempted to install a 12mm antibumpsteer shim kit in the front but noticed with the increased rack height it was making contact with the front sway bar. If I add maybe a 1/4" spacer behind the bushing bracket I'd get the clearance I'd need. You guys see any ill effects by pushing the swaybar 1/4" forward? I don't see any other way around this.
thanks!
thanks!
