spark plugs? how often replace?
Old Feb 27, 2017 | 07:58 PM
S2000_916's Avatar
Default spark plugs? how often replace?
how often is it a good idea to change plugs? I torque before every season but what is a good rule of thumb?
Old Feb 28, 2017 | 03:33 AM
Chuck S's Avatar
Are your plugs loose when you re-torque them? Just curious. Never heard of any requirement to do this.
Maintenance schedule in the pre-2006 owners manual specifies new spark plugs at 105,000 miles. In 2006 and later change whenever the Maintenance Minder calls for them. Plugs are comparatively cheap and I changed mine at about 40,000 miles when I did the valve adjustment in my 2006 car. They were out anyway (engine is easier to turn over by hand without them) so I put new ones in.
-- Chuck
Old Feb 28, 2017 | 10:54 AM
S2000_916's Avatar
-- Chuck
i read somewhere to check plugs so i just made it a habit. i always notice the plugs back out a little bit. this is on both ap1s. nothing crazy but after a few years i could see it being a issue.
Old Feb 28, 2017 | 10:59 AM
King Tut's Avatar
When you get misfires.
Old Feb 28, 2017 | 12:39 PM
jyeung528's Avatar
what are you torquing to initially? honda revised the torque setting from 18 ft/lb to 22 ft/lb.
Old Feb 28, 2017 | 01:11 PM
S2000_916's Avatar
i just go by feel
Old Feb 28, 2017 | 01:36 PM
jyeung528's Avatar
might wanna recalibrate your feel and see if you're actually getting it to 22 ft/lbs.
also, depending on which plugs you use, on initial install there might be specific install instructions such as 3/4 turn after contact or something like that.
i suspect feel is the culprit here, plugs shouldn't be backing out.
Old Feb 28, 2017 | 02:39 PM
cosmomiller's Avatar
Top Answer: 1
-- Chuck
Me too.
Billman recommends 22 ft/lbs. He had a spare head and ran a test to see how far he could torque a plug before failure. As I recall he went to 70-80 ft/lbs before the plug failed. The threads were still intact.
All kinds of problems rise to the surface from loose plugs. Just torque them down right the first time. Don't use anti-sieze on NGK plugs. They have a coating called trivalent plating. This silver-or-chrome colored finish on the threads is designed to provide corrosion resistance against moisture and chemicals. The coating also acts as a release agent during spark plug removal.
Old Feb 28, 2017 | 03:34 PM
freq's Avatar
Originally Posted by S2000_916
i just go by feel
I have my elbow calibrated yearly too.
Old Feb 28, 2017 | 03:51 PM
s2000sccaracer's Avatar
Since this is the Racing and Competition forum, change them at least at the beginning of the race season, whether or not they need it. For everything else that you are spending on a "race" car, spark plugs are relatively inexpensive.
