SPC Camber Joint vs J's Racing S1
Old Apr 15, 2011 | 11:02 AM
  #81
Aristoi's Avatar
Originally Posted by dc_s2k
So, which hardrace part adds camber? Is it the one with the ball joint or the one with the spacers and the ball joint? The reason i ask is I found this kit on ebay, #6622 that does not come with the spacers. The other kit #6621, that does have the spacers/plates does not seem to be for sale on ebay right now.
Do not get the 6622, it is not offset and will give you no extra camber. It is the offset ball joint that gives you the camber not the plate. The 6621 is offset to give you extra camber and it has the roll center plates which you may or my not want to use depending on your situation.
Old Apr 15, 2011 | 05:19 PM
  #82
PilotSH's Avatar
Do NOT but the 6622 joints. All they are are taller versions of the stock balljoints and will not gain you any camber. You need to buy the 6621 joints. Those are the ones with the offset that will help you gain camber.
Guys, I've got a ton of PMs asking me about these camber joints, and I think they are sold out at the moment. If you guys are serious about buying these and want to get them quickly, maybe I can get him to airship a bunch of them to him. I will do my best to try to keep the price the same, but it may cost slightly extra for shipping, is that ok? I'm thinking that if at least 10 ppl put down money right now for them, that he'll consider it. If you guys are interested, lemme know.
Old Apr 19, 2011 | 11:40 AM
  #83
dc_s2k's Avatar
Nuts. Velocityshop will not be getting them in for 5 weeks. I need this part asap as there is a track day coming up on 4/30. What other ordering options are there for the hardrace or J's part?
Old Apr 19, 2011 | 11:50 AM
  #84
LickyMYwalker's Avatar
any of the vendors im sure can get them to you air freighted from japan
Old Apr 19, 2011 | 12:51 PM
  #85
//steve\\'s Avatar
Don't bother with the extra plates. I had a set of J's L1 joints on my last s2000 that I picked up entirely b/c I wanted the extra camber and the price was right. Picked them up used and in excellent condition for like $220. These were the older 1 piece RCA camber joints. It was nice to get the extra camber but I didn't feel anything different by having that little bit of roll center correction.
Old Apr 19, 2011 | 12:53 PM
  #86
FF2Skip's Avatar
Originally Posted by WynnS123
Originally Posted by robrob' timestamp='1300756769' post='20384416
Another problem with the adjustable ball joints is the points hit you take with NASA in performance touring or time trials. You take no points with the J's part.
I thought the J's camber joints were 2 points. Am I wrong?
From Page 27 in the CCR for Time Trials under Suspension:
19) Alteration of ball joints/dive angles +2
This is my unofficial take on the rules: If a part is not oem or exactly like oem, it must be assessed. If it is NOT assessed in the rules, the part is not legal for use. The fact that said part also increases possible camber is a slam dunk for a points assessment. There is no "free" add'l camber for the S2000, non-adjustable or not.
Under No Points Mods on Page 30, it clearly states that such a part is NOT a "no-point" mod:
1) Simple camber, caster, and toe adjustment by any method that does not alter suspension
mounting points (unless the modification used is otherwise assessed points above--such as
control arm, ball joint, and relocated mounting point modifications).
Slotting of the OEM
bolt holes and removal of material from the top surface of the OEM strut/shock tower to the
extent necessary to allow simple camber/caster adjustment is permitted.). Bolt on
camber/caster plates are not assessed points.
Old Apr 19, 2011 | 02:31 PM
  #87
robrob's Avatar
Yea, I stand corrected. The rules now hit the J's Racing ball joints with the same +2 as the SPC adjustable ball joints. Thanks for the clarification Skip.
Old Apr 19, 2011 | 04:05 PM
  #88
FF2Skip's Avatar
Rob, you know how I feel about that whole scenario. I still believe that transparency has not been evident in the rule changes since Rene' did some driving at Mid-Ohio; one day at that(subsequent days were wet). Whether there was an intentional singling out or not, to the casual observer, the S2000 was picked on. What was worse was that the model that did the whooping came out better than the other two groups of S's minus the CR. Best S to have in TT- '06+, then AP1, and then non-flashable AP2's.
Old Apr 19, 2011 | 08:18 PM
  #89
Orpheus's Avatar
here is a local sale for the j's racing version + roll center plate:
https://www.s2ki.com/s2000/index.php...otificationlog
gl.
Old Apr 19, 2011 | 08:32 PM
  #90
IntegraR0064's Avatar
Like I said before, Science of Speed got it to me air freighted from Japan either the next day or the day after that, and it was normal shipping rates like you'd pay in the US.
