spoon brake discs cracking
Originally Posted by krazik,Apr 5 2005, 09:33 AM
modern pads don't outgas significantly, if at all.
what happens under break-in isn't a reason tho to run drilled rotors all the time. You aren't expecting max performance on an non bedded pad.
When you're bedding a pad all sorts of stuff is happening, I was speaking from a standpoint of once a pad gets into its "use" cycle.
great detailed post cthree, seems to sum things up pretty well
the cracks I have are only 2-3 mm radiating away from some of the drill holes
Q: should I change them asap or carry on tracking ?
an aquaintance assured me that porsche owners have similar occurences when tracking, but keep on using them
Robin
Robin
For me I always try to err on the side of caution; if it were me I would be at the Hondaa dealer picking up some OEM rotors before the next track event, but that is just me...
Good luck, stay safe.
Take a spare set to the track with you and inspect them after each session. If the cracks develop further you can swap them out before they break. Remember you can only see one of 4 surfaces so there is always the chance that what you can't see is worse. You should always carry a spare front rotor to the track and routinely inspect the rotors between sessions regardless.
guys I know this sounds dumb, but how do I paste images into these posts ?
I have a couple of small jpeg images of the cracks I'd like to share
and cthree you're right I'll take a spare set of rotors (I have a pair of powerslots)
but do I have to junk the almost new panther+ pads when I change ?
regards
regards
