spoon brake discs cracking
euroS2K, glad to hear! I have found over the years the low cost to replace the rotors with OEM parts is well worth it. There are enough things to worry about I figure this is one I don't have to think about. In fact I just put new rotors on the front this past Saturday, and although mine were filled with little tiny check marks, they looked almost as thick as the new ones; but they still went into the trash...
Yes, any extra cooling you can add is a good thing.
Originally Posted by jyeung528,Apr 26 2005, 01:55 PM
how much faster does the cobalt RACE pads wear out the OEM rotors compared to the cobalt GT-Sports?
Guys,
I know that one should change pads when changing discs, but the Panther+ plus pads having little wear, it is tempting to keep them when I swap the cracked spoon discs for the powerslots...
is this an option, or would I be making a big mistake ?
thanks for your feedback
regards
regards
WOW I was going to recomend using slotted rotors only, but after seeing that picture............
I still recomend slots over drilled holes. I suppose you need to have a good manufacturer.
I got my rotors Cyrogenicly treated.
well kaolite was soooo right, the new powerslot rotors lasted about 20 laps of a nice twisty circuit called the Val de Vienne and each has now a single radial crack across almost the entire disc surface, even worse than the posted picture ... but also starting from the slot/exterior intersection ....
so I drove very gingerly 200 miles home using the gears and handbrake to slow down !!!!!
obviously carbotech panther+ pads are just too agressive ...
having received my replacement spoon discs, I'll put them on with project
Originally Posted by euroS2K,May 8 2005, 02:39 AM
any other ideas ??
The rest of us get lap after lap after lap of reliable braking power from plain old OEM blank rotors. And they cost less, too.
