Square setup without rear wing
Adding tire up front is a cheap way to make the car faster. Whether people want all the added grip up front or want to move some of the added grip to the rear using a thicker front sway is a matter of taste. Going nonstaggered and re-balancing with a thick front sway doesn't put you back where you started. It gets you the stock-like balance, but more total grip and more total speed. That's why people do it.
Originally Posted by GT Motoring II' timestamp='1371739321' post='22620289
[quote name='billios996' timestamp='1371738484' post='22620254']
Are you saying you want proportionately more grip in the front than the rear? This can't be the case otherwise you wouldn't change the sways to add grip back to the rear.
So why add more tire in front but not in back? If you go to a 255 in front more front grip, you can stuff a 275 (or bigger) in the rear on a 10" wheel to keep the stagger. Is the lack of 10" wheels the limiting factor?
There is a reason that most of the fast s2000s are on non-staggered setups - it's faster.
[/quote]
Could not have said it better.
caleb2483
Oct 26, 2010 12:20 PM
