Square tire setup for autocross
It's time to start thinking about racing and autocross.
My two year old staggered setup V710s are all used up, and it's time to get new tires for autocross.
I found myself stuck between either pushing (with a somewhat stiff sway bar setting), or having rear wheel spin (with one setting less stiff) with the 245/275 staggered setup.
And I had some rubbing on my front left with 245s so I'm not heavily inclined to go to 275s all around. The added rotating mass is also a consideration.
I have the Gendron medium-stiffness front sway bar.
Would 245s all around, with that bar, be a reasonable setup? I'm a decent autocrosser, but not threatening to trophy at nationals any time soon.
245 all around is a quite reasonable setup. I have used both Hoosiers and Kumhos with that setup. You may want to go stiffer on the front swaybar. I have the Gendron 1.25" solid bar and set it full stiff when I ran the 245x4 setup. It was also full stiff for the 245/275 setup, just to keep wheel spin in check. Rear toe was set to zero to help neutralize the handling balance in all cases above.
Thanks, John. I like that answer.
What size 245s do your recommend, and what brand?
And is it likely enough that my medium-stiff Gendron bar is inadequate, that it would make sense proactively to buy a new one? And, if so, what's the right one to get (given the difficulty of adjusting my three year old Gendron bar quickly)?
Thanks.
Mark
Thanks.
Mark
245/40-17 is what I used, I think taller would rub in front. If you're going to spend the money on DOT-Rs, you might as well splurge for the Hoosiers, especially in the frigid northwest. The Kumhos are pretty good -- I beat Joey on them once last year -- but I think the Hoosiers are just slightly better.
As for the bar, I can't say with confidence whether the hollow 1.25" bar will keep the rear end behind you. The only setup I ever ran was with the 1.25" solid bar set to full stiff. You might be able to get away with the hollow bar if you toed in the rear wheels a bit. You can probably buy a new solid center section directly from Speedway if you can figure out the correct length.
A lot of people have gone up to the 1-5/16" solid bar that Bill has custom made, although most of them have AP1s and really need it to kill the wheelspin.
I have found the "medium-stiff" hollow bar to be more than adequate for the 245/275 setup. I think more important than rear tire size (as there is only one real option up front) is your alignment and the surface you typically run on. I am toed in 1/16" in the back and run on sticky concrete most of the year.
Definitely go with the Hoosiers.
Originally Posted by BowlofRice,Feb 8 2011, 10:00 AM
Hey Mark, if you decide to part with your gendron bar I'll pick it up.
I was thinking going square soon and will eventually (if not already) need a stiffer front bar.
I expect that I will have the bar, the end links, and a number of brackets (always good to have an extra on hand; ask me how I know).
Thanks.
Mark
Thanks.
Mark
-Marc
Originally Posted by sirbunz,Feb 11 2011, 10:18 AM
Careful with your decision. The Ankeny bar creates some weird steering feedback/front end stability when compared to the Gendron. I recommend the 1.375" bar. You can always get a new center section. Maybe you will like the Ankeny though. Jadrice switched back to the Gendron on his CR because of this. Between the two of us, we have tried the Comptech (v2), Saner, Gendron, and Ankeny. The Gendron with the updated mounts is the way to go IMO. Nothing against the other bars, just feel the Gendron is the best bar for my preference.
-Marc
-Marc
