STR in Bly'ville!
Old Jun 6, 2011 | 07:47 AM
glagola1's Avatar
Default STR in Bly'ville!
Wow, so 22 folks are signed up for STR at a relatively low turn out event. That's pretty awesome. Notibly, Marc P. looks like he'll be joining the ranks! That's cool.
So, over the span of the next three evenings I have a lot to do. Before work this morning, I bolted up my Enkeis to scrub the sticker Dunlops in some. Next I have to roll the fenders, install springs and lower the car and do a home alignment. Working in the parking garage at work sucks... maybe as much as working in front of my rented storage facility.
Lastnight, I had a crazy idea to run my car as is (B-stock) but with the tires and wheels and see what needs addressing. But... I'm second guessing that and will probably end up installing the springs I happen to have which will put the set up at 800 fronts and 750 rears. That's a bit more aggressive than I have a hunch I will need in the rear but maybe it's better than stock springs.
Anyway, see ya'll there! I'm excited to see what happens.
Old Jun 6, 2011 | 10:48 AM
yellowdog's Avatar
Run it as is.
Please.
Old Jun 6, 2011 | 11:37 AM
sirbunz's Avatar
Install the springs! We all know you like working on the car last minute! I plan to be there in STR ... unless Jadrice decides to come.
-Marc
Old Jun 6, 2011 | 11:53 AM
glagola1's Avatar
Yeah, springs are going in. Seems like a waste of an event otherwise.
Old Jun 6, 2011 | 12:20 PM
762's Avatar
762
You can try run 1 with one end link on the rear bar disconnected. If balance is good then you can quickly take the bar off all together and save weight. If to pushy just re-connect it. It seems like AP1s seem to like running no rear bar more then the AP2s.
Old Jun 6, 2011 | 01:25 PM
josh7owens's Avatar
I'll be there in DFL. HAHA, god I hope not! I'm doing alot of testing on friday at the evo advantage, I got to get used to this softer bar thing. Anyone else doing the advantage?
ernisill
Oct 23, 2007 04:06 AM
DonTTgo
Nov 19, 2004 08:57 AM
dreamgetter1
Dec 17, 2003 10:15 AM
Sid
Nov 21, 2001 12:12 AM
