View Poll Results: What tires (primary) do you use?
Hankook R-S3 255
45.13%
Hankook R-S3 245
3.98%
Dunlop Star Spec 255
21.24%
Dunlop Star Spec 245
5.31%
Toyo R1R 245
0%
Toyo R1R 255
0%
Other
20.80%
BFG Rival 255
3.10%
BFG Rival 245
0.44%
Voters: 226. You may not vote on this poll
STR Prep - Wheels and Tires
Old Mar 9, 2012 | 09:55 PM
  #121
Random1's Avatar
It's also a good idea to maintain all the fender liner clips meaning check them before/after events and replace them. If you are missing enough of them and the tire catches there is a chance the liner could be pulled out.
The clips can be bought on ebay in bulk for very reasonable prices. I keep a bag of each the fender and under pan sized clips in my event tool box.
Hitting cones on the front corners tends to knock them out and I randomly find them missing over time in various places.
Old Mar 10, 2012 | 11:53 AM
  #122
PedalFaster's Avatar
Andy Hollis just posted this handy guide: https://www.facebook.com/notes/holli...45008598916447
Old Mar 10, 2012 | 11:29 PM
  #123
legend4life's Avatar
Originally Posted by mLeach
The only liability is the tab that the liners attach to. Push them up as far as you can against the fender. The liners will get holes, but that's no big deal.
New to this, and finding it confusing. Is the tab the inner fender lip, are you suggesting to roll it, and most people in STR are running rolled fenders?
Also how are the tabs relocated?
Old Mar 11, 2012 | 08:01 AM
  #124
IntegraR0064's Avatar
If you take a couple fasteners off the liner and look you'll see exactly what people are talking about, otherwise it's tough to explain.
Basically there isn't really an inner fender in front, there are tabs sticking out that the liner mounts to. These have to be bent up, which is effectively like rolling the fender but doesn't require a fender roller, and yes this is pretty much necessary in the front unless you want to run at stock ride height. The rear the fenders don't have to be rolled unless you're trying to be very low.
Old Mar 11, 2012 | 11:02 AM
  #125
Random1's Avatar
The "tab" is the part of the front fender lip that has the hole for receiving the fender liner clip. Once it is bent up it is no longer used. Yes most in STR roll the fender lip which includes two tabs. From the top center of the fender lip you only need to roll about 8" inches on either side of center. The fender liner will wear through at certain points. I just cut out a strip about 3/4" wide between the two tabs using a box cutter (razor).
If you do not roll and are running 255R17/40s then you can get the tire caught up on the fender edge. How bad depends on how much camber and ride height. This can pull out your fender edge if you are in a slide counter steering (tire rotating outward toward the fender edge). It also can damage (shave) the tire. See photos below.
There is no need to roll the back fenders unless you are running a strange off set. The +62 or + 63 offset that most run on the 9" wheels works as is on the back regardless of ride height, no rolling.
Early fender liner wear, the tab is the metal behind the liner where the hole is.
Old Mar 12, 2012 | 02:07 AM
  #126
Need to go look under fender and pull the clips out like Jon said, but thanks for the explanations and pictures, very helpful.
So once the tabs are bent up and no longer used, how/where are those clips relocated? Is the rest of the lip that is rolled still done the traditional way using a roller?
I'll be running 255/40/17 on 17x9 +60, would like to try low ride height of 12.25-12.50 if possible. Random1, I see you ran those heights, did you have any serious issues? Did you find any extra benefits from running this low, and also with the positive rake?
Old Mar 12, 2012 | 05:25 AM
  #127
nlink720's Avatar
PM'ed to continue discussion specific to your car and with respect to the upcoming test and tune.
Old Mar 15, 2012 | 01:04 AM
  #128
Still wondering about this. Seems like there are different answers, depending on ride height, as people at 12.75-13" can get away with no mods at all, while others say bent tabs and/or fender roll required.
Random1, mLeach, IntegraR0064, or anyone know what exactly is required to safely run 12.25"/12.5" in terms of fender mods?
Glagola1, what ride heights do you run, did you need to mod your fender to do so?
Old Mar 15, 2012 | 01:58 AM
  #129
josh7owens's Avatar
Front fender tab rolling is needed for extreme low ride height.
Old Mar 15, 2012 | 02:37 AM
  #130
Where do the clips get relocated to from the tabs that are bent? Is a roller tool required to roll the lip? Is trimming the liner needed as well?
Is there some tab or bumper tab in the rear that needs to be relocated?
Also, what size clips fit right/best? I see ones on ebay with 15-20mm heads, and 9-11mm stems, 8mm hole.
