sway bars?
Old Aug 10, 2006 | 09:37 PM
whitehonda2000's Avatar
Default sway bars?
just wondering which would be the best sway bar setup for MY06. im planning on purchasing sway bars for my first mod, and if it would be best to get just the front sways or front and rear? if i get the front and rear what would be the best setup? if just the front what setup would be best? any suggestions please!
Old Aug 11, 2006 | 06:21 AM
CRDMS1's Avatar
There is no simple answer to your question. What are you planning to use the car for? What handling characteristic are you trying to fix or improve?
Old Aug 11, 2006 | 09:08 AM
loudes13's Avatar
drive it stock for a while 1st.
Old Aug 11, 2006 | 09:09 AM
pantyraider's Avatar
Cusco
Old Aug 11, 2006 | 09:59 AM
CRDMS1's Avatar
Great advice if you don't know what you're trying to fix.
Old Aug 11, 2006 | 02:06 PM
loudes13's Avatar
we'd assume to '06 is more docile than previous ones. So why mess it up until you do a few events?
the S has an ok camber curve, so body roll alone doesn't hurt that much.
Old Aug 11, 2006 | 07:36 PM
I have actually taken my car to autocross event after break in. The one thing that I noticed was, the car had a tendency to "duh" slide rear first and then front when pushed to limit(VSA off). I was trying to see where the car breaks loose and if its possible to make the rear-end not break to easily. that is what im hoping to get out of the sway bars. more practice or any suggestions?
Old Aug 11, 2006 | 07:40 PM
payneinthe's Avatar
You're still too new in the car to be handicapping your car control skills with mods. Yes, a stiffer front swaybar will make your car less tail happy, but then you'll never learn what driving an S2000 is about. As long as you've got stock tire stagger, you don't need a swaybar to balance the car.
Old Aug 11, 2006 | 08:44 PM
rlaifatt's Avatar
Good point. People (like myself way back) are often too quick to dumb down the car to feel more secure rather than learning to drive the car faster as engineered.
Old Aug 12, 2006 | 03:21 AM
CRDMS1's Avatar
I know it sounds like joy-kill, but the advice is sound. You should drive the car for a few events before passing judgment on what to *improve* for autocross. My first autocross in the S2k was @ss end all over the place, even after several seasons in a different car.
There's an autocross FAQ stickied to the top of the Racing & Comp forum that you can reference if you like. Not all the guidance is pertinent to your model year.
