Testing out G-loc brake pads
#41
I would strongly recommend you try the R12's on the rear first. It's never a good idea to change both the front and rear at the same time when you are trying to get a compound dialed in. If the change works then you you know exactly what worked. My two cents.
#42
Hey Danny, glad to see you on here! I think I may do just that. Would you recommend I stay with the same brake compound in the front when moving to a bigger brake system? We're planning on having our V8R STR-43 kit on my car for testing in late September. I may just call you and order a couple pads to test out what works best.
#43
Danny is the man.
junky u have to play around with the pad compounds and wat bet works for u. But Danny is right with the r16/r12 setup because they have been proven by global time attack winniners here in California.
#44
I'm running a 275/315 stagger, which is why a R16 came into question as a possibility for me in the rear, however I went with the safe option and went with the R12.
Id love to be able to manual adjust the f/r brake bias, but don't know enough about who makes an applicable option.
I'm running RBF660 this year.
#45
Yeah I am running ducting at all 4 corners.
Thanks for the tip on the bias adjuster.
#46
