Thermal (Gold) Wrap advice
IMO if you need more cooling help 1st go to a bigger radiator, that in itself should do the trick. Then higher flowing fans, and or a oil cooler. Not saying the foil does not work but as noted it only works on one type of heat and it's effects are probably minor compared to a larger radiator. You can also vent the hood.
http://www.mishimoto.com/honda-s2000...nce-00-05.html
If you are not boosted you really should not need any of these mods.
An oil cooler does not address intake temps either, however, it can offload some of the cooling needed by the radiator.
Venting the hood could definitely pose a solution.
From his post the only real goal I can see is to use gold foil to make his engine bay look cool. If you want your engine to run cooler do what I said, oh and get an new lower temp thermostat too.
This I do not get: One of the main things he noticed was his VTEC crossover wont go higher anymore ( VTEC would be at 7k-7200 after hard sessions at the track).
Whatever it is I do not think gold tape will help. Taking more heat out the engine with a bigger radiator and oil cooler will help the engine run cooler than it is far better than gold tape.
There is no need to get a lower thermostat and if the current radiator is already doing the job, more heat will not be extracted. Given the current foil tape is focused around the intake and that he's looking for differences in heat soak, a radiator and oil cooler will not aid here.
Oil cooler is always a good idea on a tracked car. I agree, most of the other places he listed are worthless considering that is where the heat is already contained.
08s2000CRbackinblack
Aug 5, 2011 10:43 PM
. LOL
