Tire pressure relief valve, thoughts?
Old 03-25-2014, 10:30 AM
gptoyz's Avatar
Default Tire pressure relief valve, thoughts?
Has anyone ever tried the long acre tire pressure relief valve kit?
http://www.summitracing.com/parts/lng-50000/overview/
I know a pyrometer and tire temp range is more inline with optimized tire performance, but how do these perform?
Old 03-29-2014, 06:53 AM
gptoyz's Avatar
Anyone
Sent from my iPhone using Tapatalk
Old 03-29-2014, 04:41 PM
andrewhake's Avatar
I have always wondered if someone made something like this. If I understand correctly, you basically setup a maximum pressure and as the tires heat up the pressure is bled off accordingly? So you could setup to never go beyond 38 psi hot for example?
It looks like these require drilling an extra hole in the wheel though so that is pretty far from ideal.. Couldn't someone just make a valve stem cap or valve stem with the same function?
Old 03-31-2014, 01:37 PM
speedengineer's Avatar
I've wanted to do something like this for years. Alas, they are illegal for NASA TT/PT competition. I'm not sure about legality for other NASA and SCCA classes, but if they're just for track days, then why not!
Old 03-31-2014, 04:18 PM
gptoyz's Avatar
Damn crazy that their is virtually no info on this topic hahha
Old 04-01-2014, 06:29 AM
BuggyofMildDiscomfort's Avatar
The problem with stuff like those is unless they have a lot of internal damping and low internal friction, they'll let a bit of air out for every bump and chassis movement that loads the tyre carcass.. you'll always end up with less pressure than you want as it'll bleed it off through the race all the time.
Old 04-01-2014, 06:42 AM
cdelena's Avatar
Although I never tried them I did pit with a guy who did and had the same comment that they were not appropriate for most track situations.
He said that monitoring shows very large temp/pressure changes over the course of a lap so that bleeding at very high pressure time will leave you with less inflation that you want after that period with negative affects for the next lap.
s2krazy01
08-31-2010 08:55 AM
triman54
04-06-2009 05:49 PM
ae86pwr
08-05-2008 08:32 AM
stocky
07-31-2008 11:12 PM
Riceboi
10-25-2007 03:11 PM
Quick Reply: Tire pressure relief valve, thoughts?
