Tire sizes... let's re-open this can of worms
Well, before we all agreed the 275 rear and 235 front on ce-28n's (7.5" front and 9" rear) was the way to go. But, as the Dude would say, new sh!t has come to light, man.
Rob was running 255's all around on 17 x 9 + 63's last time I saw him and that seemed to be working quite well.
My current tires are totally dead, so I'm looking to order a new set of wheels and tires before the big willow event later this month (yes, I'm actually going to start coming to events again!).
I'm planning to order 17 x 9 + 63 wheels (looks like I can get a hook-up on the Buddy Club P1 Racing QF forged wheels).
So the question is what size tires should I use? 255? 275? Stagger with 275 rear and 255 front?
Also, does anyone know if the new Nitto tire is worthwhile? Or are the RA-1s still the way to go?
Yeah, the rule says only that the rear has to be no more than 275.
I think 275's in the front will rub. 275's are taller than 255's. I'd run 255's all around like Rob. Alex (Honda Legend) runs I believe 245 16's all around in Honda Cup and he's embarrassingly fast
BTW, if you go equal all corners you will definitely need a wing.
.BTW, if you go equal all corners you will definitely need a wing.
Hmmm... I'd like to keep the gearing correct, so the 255 option is attractive, but I can't afford a wing and I think it end up being will be an issue at speed.
Might have to settle for the gearing detriment of the 275s.
