Toyo RA1 on AP1 wheels.
Old Feb 9, 2008 | 11:37 AM
Johnny Rotten's Avatar
Default Toyo RA1 on AP1 wheels.
What is the best width of Toyo RA1 tires for use on the stock AP1 rims, Given the Rim width I can probably fit something on that wider than the stock fitment
however I expect there is some trade-off. ie rolling the tire severely due to sidewall compliance, Then again they are stiff tires?
Some experiences would be helpful
Thanks
Old Feb 9, 2008 | 11:59 AM
CobraTi's Avatar
I autocross with 225/50 in the front and 245/45 in the rear and they look about perfect on the wheels I think. You could go 245 all around if you really wanted. The 255/50 they offer is probably too tall for the rear.
What sort of racing are you looking at doing?
Old Feb 9, 2008 | 12:00 PM
cuonice's Avatar
The most popular sizes for OE wheels is the 225/245 combo as stated above.
Old Feb 9, 2008 | 12:07 PM
Ludedude's Avatar
Administrator
That's what I used to use.
Old Feb 10, 2008 | 03:29 AM
I'll be doing the odd Autocross but mostly solo1 track type events. I'm planning to have a set of dedicated track rims and tires so I figured it well worth it to get the R compounds.
All my buddies are running RA1's as well so
It makes comparing cars and times a little easier.
So you're not rolling to the sidewalls heavily with this width?
Thanks for your help
Old Feb 10, 2008 | 04:09 AM
ZDan's Avatar
205/245
205/225
I've run the above combinations this past year. You won't go far wrong with any of them. 225/245 preferred, but in my case, with Kumho VictoRacers, they didn't "look about perfect" at all. The fronts bulged out a lot, I initially thought they'd put the rears on the front! Personally, I wouldn't try 245s on the 6.5" front wheels.
03S2
Aug 4, 2011 09:59 PM
pimperthanu
Aug 7, 2009 02:59 AM
ktrojan
Apr 17, 2009 11:11 AM
armodis
Sep 24, 2007 09:54 PM
evolvedAP1
Sep 7, 2006 12:57 AM
